is there a DIY for changing out the tc projectors?
Old Aug 15, 2006 | 04:47 PM
-JoKeR-'s Avatar
Default is there a DIY for changing out the tc projectors?
got some off of ebay and some HIDs but im tryin to figure out how to change out the headlights
Old Aug 15, 2006 | 04:54 PM
Papispico's Avatar
tC squad
the bulb...or the entire lens?
Old Aug 15, 2006 | 05:08 PM
Sniffs's Avatar
To remove the housing itself, you have to remove the front bumper.. it's like 6-8 bolts holding it on, pretty easy to remove.. the light housing itself is held on by a few plastic screw type inserts and a few screws..after you remove it all, the whole housing just pops off.. to separate the 2 housing pieces, that's another matter.. you gotta bake them to separate the 2 pieces....
Old Aug 15, 2006 | 05:20 PM
-JoKeR-'s Avatar
thats all i needed to know...i can get the bumper off but i was trying to figure out how the housing was secured
thanks
Old Aug 15, 2006 | 05:26 PM
SquallLHeart's Avatar
take off the bumper and you should see what you need to remove.
Old Aug 15, 2006 | 06:01 PM
Sniffs's Avatar
there is a clip under the headlight housing that secures it, after all the bolts are removed, you need to pull it forward then off.. what I mean by pulling it forward is pull horizontal to undo that little clip..
Old Aug 15, 2006 | 07:31 PM
Neothin's Avatar
i use a flat screwdriver to gently separate the clip so it pops out mroe easily.
Old Aug 15, 2006 | 08:24 PM
Sniffs's Avatar
^^ that works also.. probably easier too..
archael666
Mar 19, 2019 11:52 PM
RY_TC07
Jul 18, 2017 05:18 PM
elwaylite
Apr 30, 2015 02:31 PM
mrsocks
Jan 20, 2015 01:29 PM
carid
Jan 8, 2015 11:33 AM
