engine code question
Old Aug 19, 2006 | 01:01 AM
tom0613's Avatar
Default engine code question
were on th engine block does it say 2az fe just bought a motor and cant find the FE on the engine block it only says 2az and some numbers right under that were should i look fo the FE letters
Old Aug 19, 2006 | 03:22 PM
TcPrincess's Avatar
it doesn't say fe.
Old Aug 19, 2006 | 08:59 PM
tom0613's Avatar
no were whould i look for the fe or ar all 2az the same
Old Aug 20, 2006 | 05:07 AM
CuRiOuSfIsH's Avatar
dont know if it's stamped on the car, but various oil filter sites list it as 2AZ-FE
Old Aug 20, 2006 | 05:20 AM
TheQuietThings's Avatar
well, youre not going to find FE, because FE is the code of the head. 2AZ is the engine code.
Old Aug 20, 2006 | 07:07 AM
soros151's Avatar
it says KA24 I think, on the block.
Old Aug 20, 2006 | 07:11 AM
KA24? that was a Nissan engine used in the 1st gen. Altima, and 240SX
Old Aug 20, 2006 | 07:31 AM
soros151's Avatar
I know, just look on the right side, mid-place and look at the engine block, it says something like K20 there or KA something. I don't remember what exactly said, but I know it starts with a K.
Old Aug 20, 2006 | 02:44 PM
are you sure youre not imagining things?
Old Aug 20, 2006 | 07:46 PM
soros151's Avatar
Am I?
and yes it does also say 2AZ on the lower part of the engine, right side, near the tranny. Beside the OEM header.
Old Aug 21, 2006 | 01:37 AM
^^^ apparently not, but K20 and KA codes are far from anything Toyota makes.
Old Aug 21, 2006 | 01:51 AM
tom0613's Avatar
yea mine says k33 and 2az
Old Aug 21, 2006 | 02:07 AM
Xenon_tC's Avatar
mine says this
i wish
Old Aug 21, 2006 | 03:27 AM
HP_Pirate's Avatar
the k code is just a casting code. it has nothing to with the engine type. and the other letters below your 2az are the serial numbers for the engine.
the fe is for the head, you should find it somewhere on there.
Old Aug 21, 2006 | 03:50 AM
soros151's Avatar
I told ya that I knew there was K something on the engine block. I did not assure you it was neither of those. So step back.
Old Aug 25, 2006 | 02:57 AM
tCduck's Avatar
Its most likely just a manufacture code for the block. But ill have to check that out, where on the motor is it.
Old Aug 25, 2006 | 11:18 AM
soros151's Avatar
The first photo is from the mid section of the block at the right. The second one is at the right of the OEM header (if you still have it) a little lower.
daniinpitt
Apr 4, 2015 08:07 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
tersmurf
Jan 16, 2015 11:34 AM
AdmirN
Jan 5, 2015 10:19 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
