Cruise Control Installation question..
Old Jul 15, 2004 | 04:00 PM
dasaint80's Avatar
Defined3
Default Cruise Control Installation question..
Is it hard to install the cruise control in the xB? I saw a couple of kits on eBay, and I've been thinking of getting it but I didn't know how much trouble it is to put it in.
Thank
Steve
_____
Old Jul 15, 2004 | 04:38 PM
wyldkard's Avatar
I had the dealer install mine, so I really can't be much help....however the guys at the dealership said it was the longest and hardest install out of everything: foglights, cruise control, spoiler, floor mats.
I wouldn't attempt it.
-Z
Old Jul 15, 2004 | 06:21 PM
thinkCooper's Avatar
I'll let you know. I just bought a cruise control from allscion. If you do a search on cruise control pictures, there's a post with a link to images of the installed unit. I think it's very do-able.
Cheers!
Old Jul 15, 2004 | 07:25 PM
mitchell's Avatar
EASY
I did it myself in an afternoon.
Dealerships want your cash.
The dealership I talked to (before my purchase) said it was the easiest cruise they had ever installed.
They were right.
Just make sure you disconnect the battery so you don't blow the fuse when installing.
I got mine from shipped from Raleigh NC for something like $207.00.
Franklin Toyota I think.
They have an ebay store.
Cheapest and Very friendly.
Save cash and do it yourself.
Old Jul 15, 2004 | 08:07 PM
cornfield's Avatar
this site needs a diy section. I think it would be really helpful.
Old Jul 21, 2004 | 11:24 PM
Took me 4 hours yesterday to install the cruise control in my xB. It could have been easier in a few of the steps, but all said and done it wasn't that complex, mostly annoying.
The multi pin plugs aren't numbered, so you have to be very, very careful to pay attention to the drawings on the plugs in the instructions. If you get sloppy you could easily pull and tap into the right colored wire but in the wrong plug.
The only disappointing part was the lower steering wheel cover. I don't have a factory manual, but assume that you need to pull the wheel to get the full lower cover off. Without fully pulling the cover, tightening the nut that fastens the control lever is a challenge. I wasn't about to mess with the steering wheel.
It works flawlessly.
Old Jul 22, 2004 | 01:17 AM
George's Avatar
Default Re: Cruise Control Installation question
Originally Posted by dasaint80
is it hard to install the cruise control in the Xb? I saw a couple of kits on Ebay, and I've been thinking of getting it but I didn't know how much trouble it is to put it in.
Thank
Steve
Check out:
https://www.scionlife.com/forums/vie...=cruise+rostra
for links to the installation manual.
Old Jul 22, 2004 | 03:35 AM
james4513's Avatar
Default Dealer installed - good price
The San Marcos, TX dealer sells the cruise control installed for $275. Cruise kits are selling on eBay for $250. Makes no sense to install to save $25. The did a fine job and I'm cruising.
Bargain with the dealer for this price.
Old Jul 23, 2004 | 03:53 AM
catlynh's Avatar
Default How about the 2005 xB?
Will this cruise control work on the 2005, and would the install be the same? I'm assuming so, but want to know for sure.
I've had my brand new xB for exactly 2 weeks today and I LOVE IT!!!!! I do need the cruise, though, as I drive 40 miles each way on the interstate every day for work. My brother-in-law runs a garage, so I have no doubt he can install. I tried to download the instructions that George mentioned above from the site in that post, but all I get is a 2 page document...no instructions.
Any help would be appreciated...I really need that cruise to make my xB perfect!!!
Thanks,
Catlynh
Old Jul 23, 2004 | 04:37 AM
George's Avatar
Default Re: How about the 2005 xB?
Sorry, they used to be there. Try this:
http://www.toyotaparts4u.com/0001679910xAxBCruise.pdf
Old Oct 27, 2004 | 08:23 PM
tcm_xB's Avatar
Default Re: Dealer installed - good price
Actually the kits are on ebay for $195 + $10 shipping.
I've printed out the instructions and gone over them today. Doesn't seem like a complex task, but more time consuming. I would like to know how you remove the steering column cover to mount the switch??
Also, connecting the unit to the throttle cable and getting the slack out pretty easy to do?
Other than that I think it should just take a short afternoon to get this done.
Thanks!
Old Oct 27, 2004 | 09:25 PM
boilerman's Avatar
Authorized Rostra distributors might be a more economical way to go. I went to the Rostra web site and found a reference for authorized Rostra products distributors. Rostra provides a listing of such distributors based on the area of the purchaser. I found that I could find the Rostra Cruise Control for the Scion xA and xB for $187 and shipping less than I found common on ebay. Also one has a company to go back to if there is a problem with the unit.
Old Nov 8, 2004 | 02:08 PM
tcm_xB's Avatar
Default B~U~M~P
Thanks!
Anyone care to answer the Q's above? I will be installing my kit this Thursday. The more I know about this install, the smoother things will go for me
Is there any cutting of wires involved?
Old Dec 27, 2004 | 09:03 PM
8BALL's Avatar
Thanks!
I installed my Rostra cruise control this morning. It was pretty straight forward and only took 3hrs to install
To remove the lower steering column cover just remove the three screws and pop it off. Two of the srews are kind of hidden under the steering wheel, just trun the wheel until you can get to them.
I had to remove some slack out of the throttle cable. Just pop out the snap-in adapter and trun it on the threaded rod. I had to do this two or three times to get it right. It was not a problem.
Another tip, instead of trying to find the power wire to tap into (there are hundreds of wires back behind the fuse block all tied in tight bundles) I got an "add-a-circuit" fuse adapter from Auto Zone and used an unused fuse on my fuse block. That was very easy. Highly recomended.
The only scary part was drilling the hole for the cruise control stalk. I guess I made the right choice because it does not interfere with anything and can be seen while I'm driving.
The cruise control works great, I would install it again in a NY minute.
Old Jan 14, 2005 | 07:27 PM
hhott71's Avatar
Buy the BEST aftermaket cruise control at **edit**
Please become a site sponsor
https://www.scionlife.com/premium/
Old Feb 8, 2005 | 01:07 AM
scionmikel's Avatar
Default Cruise Control Power
What wire did you connect for power? I'm having the hardest time understanding the Rostra instructions on where to connect? Help!
Old Feb 8, 2005 | 01:18 AM
8BALL's Avatar
Tip: Buy an "add-a-circuit" from Auto Zone or Advance and plug it into an unused circuit on your fuse block. On my xB I used the empty one above the ACC fuse.
_____
Old Feb 8, 2005 | 01:29 AM
Carlanga's Avatar
I bought mine of eBay for about 190.00 (Rostra) all together and it took me about 2.5 hours to install it. You might need to know some electronics basics or maybe not.
It is really just common sense and follow instructions step by step. If you have any questions feel free to PM me or anything and I'll try to help you out.
P.S. Not all the pictures in the instruction manual make sense.
Old Feb 8, 2005 | 02:15 AM
Max's Avatar
Max
https://www.scionlife.com/tech/
Old Feb 17, 2005 | 04:43 AM
koalaty2's Avatar
Scion life has a tech section, but just no instructions on CC installation. Perhaps everyone thought that the instructions that come with it were pretty clear, and they had nothing to add. I do not have a CC yet, but it is on my list.
