xB Wiper Noise
Old Jul 16, 2004 | 01:13 AM
CamoxBInSC's Avatar
Default xB Wiper Noise
I have a question. When I use my rear wiper it sometimes makes a grinding noise, not the noise you hear when the window isnt wet enough. It only makes this sound when it is going down towards the off position. It has happened when the window is wet or dry. Has anyone else heard this noise? It doesnt do it all the time and i know when I go to the dealership it wont be there for them to hear. So has anyone heard this? No one is ever with me when it happens so that I can get back there and see where it is coming from. Any ideas?
Old Jul 16, 2004 | 01:15 AM
bBted's Avatar
mine does that too....i tried to clean it...but still make noise....
thats why i dont use it anymore...its annoying
Old Jul 16, 2004 | 02:24 AM
Nathant888's Avatar
DeepSouth Scions
Maybe the blade is uneven and it rubbing no matter how wet it is.. Try getting some new wipers..
Old Jul 16, 2004 | 03:10 AM
NHGrafx's Avatar
Same here, mine does it also. I don't even notice it anymore.
Old Dec 10, 2006 | 08:51 PM
Otsego_Undead's Avatar
Mine is driving me nuts now. Has anyone found a solution? does replacing the wiper blade help?
Old Dec 10, 2006 | 09:55 PM
Metro273's Avatar
I removed the whole thing, no need for it since the back window is so flat, the water just "falls" off...
Old Dec 11, 2006 | 12:18 AM
kewlbox's Avatar
^^x2
I took mine off, now all i need is some money so i can get the hole filled in the right way.
Old Dec 11, 2006 | 01:36 AM
RATMACHINE's Avatar
The problem is the wiper blade itself is getting hard, if you replace it with a new non-factory one it will stop making that chattering noise. The more you spend.... the better the blade...the softer the material...the less noise.
Old Dec 11, 2006 | 02:03 AM
06B0X's Avatar
Ok so where does one get a non-OEM replacement? I've been searching to no avil.
Old Dec 11, 2006 | 02:26 AM
TheScionicMan's Avatar
Rain-X
Old Dec 11, 2006 | 06:05 AM
peteski's Avatar
I've owned my box (bought new) for less 6 months now(it was produced in Dec 2005). My rear wiper shows the same symptoms as all of yours. SO, I don't think it is caused by old blade. Unless they installed old one in the factory...
Old Dec 11, 2006 | 02:25 PM
rdclark's Avatar
Mine has also done this since Day One -- noise on the back-stroke, just before reaching the "park" position. I must remember to have the dealer look at this next week when the box goes in for an oil change.
Old Dec 11, 2006 | 03:30 PM
lufoxe's Avatar
wow am I glad i'm not the only one, I've had this problem since day one of my purchase and I always thought it must've been because it was dry, (even though it did it when it was wet) plus it never really "wiped" properly. Anyone know where to get a good wiper blade for the money (and I don't like to go to the dealership for such small things)
Old Dec 12, 2006 | 03:05 AM
RATMACHINE's Avatar
Autozone....Pepboys....Napa.....
Old Dec 12, 2006 | 07:18 AM
peteski's Avatar
I suspect that this is caused by the wiper arm itself. The way it is molded. I think that the bend in it has somethingto do with this. And it is made of plastic. Plastic is springy.
Old Dec 12, 2006 | 07:41 PM
I think it is due to the fact that the rear window barely gets wet. It would be fairly easy to test with a light spray from a hose...
Old Dec 13, 2006 | 12:44 AM
xBster's Avatar
never noticed with mine...but then it never gets wet..
Old Dec 13, 2006 | 12:56 AM
oldboxman's Avatar
8 months and 11000 miles and I have never ever turned on my rear wiper.Oh and I live in Seattle.
Old Dec 13, 2006 | 05:53 PM
vettereddie's Avatar
I have a different wiper blade noise issue. The front wipers have a tendency to rattle when I'm driving. I'm sure it is the wipers because the rattle goes away when I turn them on, and comes back with them off. The car is under a month old, and it's been doing this since the day of delivery. Can the wiper arm tension be adjusted or will aftermarket blades get rid of this?
Old Dec 13, 2006 | 05:59 PM
salteen's Avatar
Mine does it too...I never got to bothered by it cus I never use it. Only to show people that it really does work when they ask why mine is backwards and insist that it is broke
