Relocating Spare tire??
Ok my question is, Has anyone relocated their spare tire to under the car?? I did a search and well the search sucks so I don't know if this question has been asked before but wanted to know if anyone has done it and if so do you have pictures?? I've been thinking about doing this myself but wanted to see if it has been done before.
It can be done, but you need to relocate EVAP canister in addition to doing some serious bracket work. I would take bracket/winch setup from something like a Jeep and have a bodyshop weld it in. You would need to reinforce the metal where the bracket would mount also. It is a relatively easy project for a bodyshop.
If I end up doing this mod I will definetly take pictures. I need to take a look under the car this weekend and see what I can do. I'll probably draw things up for it if I end up doing it.
Originally Posted by chadfo
I think the biggest problem you will have is figuring out how to get the spare out when it's needed.
Gaining access to the spare tire is MUCH easier than getting to the spare tire from... oh... say a Chevy pickup that uses a crossmember type of bar that holds the tire up.
Mind you, this is a full size spare on the minivan. I would look into some of the other undercarriage spare tire systems on smaller vehicles. I don't work on cars anymore so I would not know what to look at? Small-er pick up trucks? Small-er vans or wagons?
I wasn't referring to the mechanism holding the wheel. I was referring to the amount of space from the bottom of the car to the ground. It would be a tight fit for a standard height car but Mooneyzs' is lowered so the wheel will probably not fit under the car much less him being able to reach it when it's mounted under there. It might be possible with the car jacked up but that's not always safe and if one of the front tires goes, the car has to be jacked up twice.
I wonder if it is possible to "reverse" the spare tire well?
Seems like a good idea, until the mechanism gets old and rusty, and iced up in a blizzard somewhere out near the Colorado- Kansas border...
Lots of older pickups had the spare like that, and sooner or later, it ends up in the bed of the truck... and stays there...
Originally Posted by jonnyp
I wonder what it would look like with a full size spare and one of those SUV style swing arm spares mounted on the back of the hatch?
brutal.
