PLEASE HELP! avic-d2 wiring
Old Nov 24, 2006 | 08:08 PM
rivas_203's Avatar
Default PLEASE HELP! avic-d2 wiring
ok so i just bought the avic-d2. on the main harness there is an orange wire that says it goes to the "illumination switch". what wire would that be in the car and on what harness would it be found. thanks.
Old Nov 24, 2006 | 10:44 PM
SquallLHeart's Avatar
connector R2 (1st one for the radio), pin 10, green wire
Old Nov 25, 2006 | 12:11 AM
rivas_203's Avatar
oh thank you. also which wire would i splice the speed sensor to?
Old Nov 25, 2006 | 12:26 AM
https://www.scionlife.com/forums/viewtopic.php?t=138455
but ehh.. you can connect to that one yellow wire in the R9 connecter.. (the same one that has the radio controls and the aux wiring) pin 3.
but everyone's been using the plug right at the ecu... 2nd plug from top.. pin 17.. purple wire
(but it seems they relocated it to pin 8 on the '07)
Old Nov 25, 2006 | 12:33 AM
rivas_203's Avatar
dude squall thanks a bunch man. yeah those wiring guides were handy through the whole install. i just gotta finish it tommorow. too dark now. unless...
Old Nov 25, 2006 | 12:34 AM
hmm.... you can always come by bamm's place sunday to finish.. i'll be there swapping leds.
he's in hayward.
Old Nov 25, 2006 | 02:34 AM
rivas_203's Avatar
ok so now i have different woes. all the wiring is fine. but the navi discs wont read and i keep getting the parking brake warning that its not hooked up properly and all that. everything else works great (normal cds, radio, video inputs)
Old Nov 25, 2006 | 03:31 AM
you connect the parking brake right? it shouldn't be grounded when it's operating..
did you void the warranty... (like you're supposed to?) if you want it to operate in that manner?
Old Nov 25, 2006 | 03:54 AM
rivas_203's Avatar
um, well the stereo wire is connected to the e-brake switch wire. the handle itself seems to be the ground. im pretty sure its all hooked up right. i dont get it about voiding the warranty...
Old Nov 25, 2006 | 03:58 AM
if you want the navi search functions and such (including video) to be usable while driving.. you need to flip a switch behind a sticker that will void the unit when you remove it.
Old Nov 25, 2006 | 04:44 AM
rivas_203's Avatar
ill check it out tommorow. but shouldnt there be a proper way to do it. i mean it should read the navi discs (while im parked mind you) and display the map regardless of whether or not the switch is grounded right?
Old Nov 25, 2006 | 04:49 AM
oh yeah.. it should display the maps and everything
it's just you can't use certain features.. (like poi search and address book. and searching and stuff) unless the safety is bypassed.
Old Nov 25, 2006 | 04:54 AM
rivas_203's Avatar
oh ok. no but my problem is that the navi discs dont read at all therefore i cant get anything navigation related to work including maps.
Rob54Monty
Feb 3, 2023 08:26 PM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
