a few questions that im sure you can find the answer too
Old Dec 17, 2006 | 05:54 AM
ilovemybox's Avatar
Default a few questions that im sure you can find the answer too
i tried the search button and all that but..
ok i have 215/45/R/17s and i would like to lower my box but it is rubbing on the inside of the wheel well now just a little but id like to lower it a inch or inch and a half do you think it would get worse
also
if i go that low will i have to get a camber kit?
i will have some pics up of my box very soon i have to say it looks very nice sittin on some GF-1s 17inch
Old Dec 17, 2006 | 04:42 PM
ilovemybox's Avatar
nobody knows?
or am i posting in the wrong area or something???
Old Dec 17, 2006 | 05:02 PM
tanakasan's Avatar
I have that same size tire, but...
Every tire mfr. actual size is different-even for the identical tire size.
Also, what offset rims do you have? That will make a big difference. Mine are 17x7, 42 offset. Zero rubs. I am at stock height. The tire (Falken Ziex512) is real close to the rear swing arm, but no rubbing.
Maybe more info will help others to help you.
Old Dec 20, 2006 | 06:31 AM
bB2NER's Avatar
Music City Scions
Yes we need more info to give an answer. When I had that size tire with 1.5 inch drop and the 10MM One Ton rear spacers I would rub slightly on the pass side front wheelwell just on the outer edge of the tire. I have since removed the spacers and am running the TRD 18' with 215/35/18 and do not anticipate any more rubbing after everything is put back on for the spring and summer.
Old Dec 20, 2006 | 07:07 AM
get correct sized tires.
217/40/17 or 205/45/17
TotalChaos
13
Feb 4, 2015 10:24 PM
IrjI619
Jan 28, 2015 05:21 AM
nastytc
Scion tC 2G Aero & Exterior
Jan 27, 2015 03:50 PM
STCxB
11
Jan 9, 2015 04:30 PM
Akachi
Dec 6, 2014 02:17 AM
