SolarGard HP22 Window Tint a Perfect Match
Just got the front windows of our box tinted with SolarGard HP 22 -- perfect match.
Also, if you are in the Pittsburgh area and you need your box tinted, you have to go to John and Mark at Advantage Window Tinting in Youngwood (near Jeanette and Greensburg). It's worth the 20 minute drive and every penny you'll pay. They were $75 for the two windows, including CRL moleskin channel liners on the inside window rubbers. We talked to 4 other places and they were all $50-$60 and had never even HEARD of channel liner tape. John and Mark did a very high quality job!
thanks guys
thanks guys
yes. It's made by C R Laurence company and comes in a 1 or 1.5 inch strip i think... they trimmed the strip lengthwise to fit the rubber after popping the door panels off.
check the posts by tintsem -- he mentions the tape also.
again, you should ask around, but the best tint people will tell you that it is a must...
if you don't, you can't get the film well below the window rubbers. After about a year (or less depending on window usage), the film can start to roll up at the bottom and the bottom corners).
Popping the door panels off is very easy on the xB.
Don't let the tint people talk you out of doing a pro job.
Check the site called tintdude.com for comments from pros.
People who know about moleskin are the same tinters who know what dryer sheets, spray sizers, furniture polish, wood clipboards, matrix-dissolvers, backrolling and etc are used for (in a tint shop). Not many - and if you found one - let everyone in your area know, he's learned his craft.
I'm really not trying to slam on your tint - it sounds like you found a true professional. It's good that you got a GOOD job (rare now) and that you're happy with it (even rarer). But, for others, just becuase your panels weren't removed or you didn't upsell and get the felt liner glued to your plastic window swipers - you can still get an incredible job done.
Last, I noticed that the tinter went to the trouble of the felt, removing the door panels and etc (and obviously has trolled the message boards). Did he go all 'show car tint job' and file the top edges of the tint and make them look even better like the factory colored glass on the back roll-up windows, or did he leave a small gap between the top edge of the tint and the top edge of the window?????
I took a look at the channels yesterday with the window all the way down. I can get my finger or whatever in between to clean the debris from the stripping if needed. Do you guys recommend cleaning them every so often? What is a good method to use?
About the filing of the tint at the top edge. How is this done? The tinter I use takes the tint to the top edge of the window, but not sure if he files it down....
Thanks for the feedback about the moleskin and removing the door panels. The guy did my first tint in 1998 on my Honda Civic. Who knows how long before that he started tinting windows, but he's been doing it full time out of his house since then....
Using a tint meter, the back, factory tinted windows allow 25% of the light through.
The front windows, next to the driver, allow 76% of the light through.
Keep in mind your local laws on front window tint, because you don't want to be out to much money when the mean officer says that you have to remove the tint.
Originally Posted by windowtint
you mean NON-tint people.... why would an actual window tinter talk you out of doing a 'pro job' ??? He IS the PRO.
so much for alleged "pros"
for someone who spent an obviously long amount of time dissing a post, you clearly can't "speak for the pros"
and hey if you actually read what I said about tintdude.com, I suggested they go t here and look for comments from pros about moleskin. Nobody suggested they post something.
"OMG" -- you need to lose the attitude dude.
I don't see the channels being a problem with my xB. I'll just make sure to keep them clean as I hardly put the windows down anyhow.
Originally Posted by MaximuS
I was actually wishing I coud remove the tint on the rear windows.
Is that possible on the XB?
The bB in Japan has clear glass though. I'm sure you could have that glass imported but it will probably be really REALLY expensive!!
It has to be DOT approved.
Just my opinion- but I would stay away from aftermarket window 'tinting'. Factories don't use stick-on films. Neither should you.
The film stuff starts peeling and bubbling after a few years, and looks like crap. And the next owner will have a hell of a time trying to remove that. Nothing screams 'ghetto' like peeling tint films. I avoid that chit like the plague when I'm shopping for used cars.
the factory doesnt install film tint becuase the US DOT wont allow it.
also, factory colored glass doesnt filter heat, UV radiation or glass breakage protection.
the way to look at it is, which is better? A window film that was installed well and lasted 7-10 years and then needs to be replaced or no film at all and after 7-10 years and interior that is faded and sun damaged becuase there was no film on it.
It's a lot cheaper easier and faster to replace a tint job than it is to restore an interior.
Any good tinter can easily remove window film without damaging the car in any way for not very much money.
Sometimes I don't get some of the people in my own local area who argue against getting window film when they come in the shop, they wouldn't dare go outside without sunscreen on, but will think nothing of sitting in a car for hours everyday with no UV protection on the glass.
