can it be moved? stupid wires
Old Aug 20, 2004 | 02:51 PM
grnxb's Avatar
Default can it be moved? stupid wires
getting ready to mount a sub box under the pass. seat and I found a problem. There are wires that come from the pass seat itself and underneath it by the a/c duct which plug into each other by the seat's inside rail. They are mounted on a bracket that sticks out about 1.5 inches. Is this wiring for the dummy lights on the dash that indicate if someone has connected their seatbelt, or are they important like for airbags? I am only planning on bending the bracket to where it doesn't stick out as much, or cutting it off, but the wiring will stay connected regardless. Anybody know?
Old Aug 20, 2004 | 03:58 PM
chucksu's Avatar
I think the ones under the pass is both for that dummy light & a air bag sensor but not sure.
Old Aug 20, 2004 | 04:45 PM
ylosfst's Avatar
I can almost guarintee it is a sensor for the saet belts. Try unplugging it and start the car. See if the seatbelt alarm comes on or not. I replaced the stock seatbelts in my focus with racing harnesses and I had to unplug that switch
Old Aug 21, 2004 | 05:06 AM
grnxb's Avatar
I sure hope it's for the seat-belt sensor or something, because the bracket is going to be up close and personal with the six-pound sledgehammer come tomorrow afternoon. Everything should be okay as long as it doesn't need that bracket.
Old Aug 22, 2004 | 02:40 PM
MotoMan_YZ400's Avatar
You pass seat is equiped with a seat pressure sensor. So if it senses wait in the seat, and the seat belt is not connected, the air bag will not deploy. If it doesnt sense any weight at all, i'm not too sure if it does or does not deploy. But when you didconnect that wire, the computer no longer "sees" the sensor. So it comes up with the "air bag error" light, and the air bag will not deploy.
(if pass. is in seat w/o seatbelt. Air bag going off can cause more damage to the person than if they had no airbag at all)
(this info i found in some article about abag safety)
Old Aug 22, 2004 | 03:46 PM
chucksu's Avatar
I think he is just changing the mounting bracket some to get it out of the way, I dont think he is unpluging the thing though. I hope not any ways for your passengers safety
Old Aug 24, 2004 | 04:14 AM
mgithens's Avatar
that is definitely the wire though, no harm in moving it...
I left mine unplugged after installing my amp and the flasher didn't flash and the airbag light came on... plugged it back in and all was fine...
Old Oct 5, 2004 | 11:10 PM
FuglyxB's Avatar
I'm going to get custom seats... how do I get the light to stay off since the new seats won't be connected?
Old Oct 5, 2004 | 11:42 PM
Max2k's Avatar
skruff
Apr 6, 2015 06:34 PM
stenger
Regional - Mid South
Feb 12, 2015 07:13 PM
yamahamx117
Dec 25, 2014 01:54 PM
JonathonK
Dec 6, 2014 12:13 AM
Switchbakz
Dec 1, 2014 12:22 AM
