Coilovers
Old Mar 1, 2007 | 04:01 PM
b_adair87's Avatar
Default Coilovers
I need to buy coilovers or springs, i dont think i will need to adjust it at all. I just want my ride to be smooth plus im on 18 but i want it to be dropped with no gap though. Any recommendations ?
Old Mar 1, 2007 | 04:05 PM
jschneideriii's Avatar
Unless your going to time-trial or race your tC, coil-overs is an expensive way to go to smooth out the ride and drop your ride height. I'd suggest looking at a good set/combination spring upgrade. You can tune the ride and height this way and save a substantial amount of money in the process.
Old Mar 1, 2007 | 04:07 PM
Neothin's Avatar
ummm you cant adjust ride height with springs ^^
i'd go with a set of s-tech's. I rock em and i have no gap up front and a finger in the rear.
Old Mar 1, 2007 | 04:17 PM
b_adair87's Avatar
Thanks well i know u cant with springs, but anyways u have 18's? And how does it corner?
Old Mar 1, 2007 | 04:42 PM
BuddhasTC's Avatar
IMO, and on my car, H-Techs provide a nice drop and a very nice ride. If you want an even smoother ride, upgrade your shocks also, Koni has some nice ones...This combo will prove cheaper than the coilovers
Old Mar 1, 2007 | 04:58 PM
b_adair87's Avatar
What all do coilovers replace? Would they be replacing like the springs and shocks?
Old Mar 1, 2007 | 05:29 PM
If you read his original post, he states he does not think he needs to be able to adjust his ride height. He does want to reduce the gap between the wheel and the 18 rim/tires. For that, he can lower (adjust) the ride height to get the look he wants with springs.
Old Mar 1, 2007 | 06:19 PM
Default Coilover defined
Coilover is short for "coil (spring) over strut". It consists of a shock absorber with a coil spring encircling it. The shock absorber and spring are preassembled as a unit prior to installation, and are replaced as a unit. This provides for optimal damping without torsional loads. Some coilovers are adjustable for ride height and hardness for tuning based on different track/competitive events.
Old Mar 1, 2007 | 06:29 PM
b_adair87's Avatar
Thanks well what would you recommend to get rid of the gap and still be good with a lip kit? It would be nice to corner better and have a smooth ride
greytc
Oct 26, 2015 07:53 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
rmz489
Sep 16, 2015 08:19 PM
ScionDP
Sep 8, 2015 02:17 AM
