In Dash Emergency Brake Wire setup HELP plz.
Old Mar 8, 2007 | 05:27 AM
NightShade's Avatar
Default In Dash Emergency Brake Wire setup HELP plz.
Ok, so i got an in dash dvd player with touchscreen monitor, etc. Well it has a safety feature that makes the vid not show when the vehicle is driving, does anyone know how to trick the system or disable it ? i want to hook up my laptop to it and use it to voive GPS software on my laptop and use the AV in. If anyone knows that would ne great. Thanks, SL.
Neothin's Avatar
what double din is it
Old Mar 8, 2007 | 05:32 AM
NightShade's Avatar
actually its a single din Dual XDVD710. i know its an old model but I wanted to see if the laptop hooked to it would work for my laptops GPS.
Old Mar 8, 2007 | 06:01 AM
Ankryth's Avatar
i'm not sure about that model in particular but many of them can be bypassed simply by grounding the brake wire
Old Mar 8, 2007 | 02:05 PM
NightShade's Avatar
grounding the brake wire? ground it to what?. thanks in advance
Old Mar 8, 2007 | 04:59 PM
Scott8's Avatar
On my Kenwood I just found a bolt connected to the chasis and secured it to that and it worked as a ground for me.
Old Mar 8, 2007 | 05:08 PM
scion07's Avatar
ive heard u can just go to a switch instead of the e brake
Old Mar 8, 2007 | 05:49 PM
know_fun's Avatar
its easier to bypass the older units. but "usually" the unit is looking for a signal from you brake. and that signal is only a 12v signal so just hook up a 12v constant to a switch and the switch to the unit . not 12v to unit because some units look for a signalbreaksignal kinda deal. just find out what kinda signal it needs and supply it.
and grounding it might work to like ankryth said
Old Mar 8, 2007 | 05:55 PM
SquallLHeart's Avatar
ground it to... uhm.. ground? (like.. the chassis?)
more older units just use that safety feature... newer ones have it built into the software and are a little bit more difficult to bypass.
Old Mar 9, 2007 | 03:37 AM
NightShade's Avatar
yeah the manual says it has to be connected to the parking brake mechanism and that i shouldnt just ground it, So im thinking ground it might make it work. but when i get the chance i'll scan the diagram on wiring to see if anyone can help. it looks like a wire is hooked up to the e-brake
Old Mar 9, 2007 | 03:40 AM
BlackRose617's Avatar
i have a panasonic and i just grounded the ebrake wire works fine...i think dual is the same along with most others.
Old Mar 9, 2007 | 03:54 AM
burninskulls0911's Avatar
thats what i did
wire from tv to switch to ground
Old Mar 12, 2007 | 07:33 AM
MPanova's Avatar
Just twist the parking break wire in with the main groiund for the head unit and it will work just fine, it will think the parking break is forever on lol
Old Mar 12, 2007 | 08:15 AM
jayzen's Avatar
I WENT THROUGH THE SAME TROUBLE... I HAVE A DUAL AS WELL. GROUND THE UNIT. IF IT DOESENT WORK, PUSH THE RESET BUTTON AND YOU WILL BE GOOD. IF YOU DISCONNECT THE BATTERY YOU WILL HAVE RESET THE UNIT AGAIN.
Old Mar 12, 2007 | 07:40 PM
NightShade's Avatar
yeah, thanks all , I will do that once i recieve my dash kit. I just hope i comes soon, but im working so much i dont have alot of time to install. errands to do. so hopefully it gets here tuesday so i can attempt to install. I post a followup/
Old Mar 12, 2007 | 07:50 PM
b_adair87's Avatar
Thats what i've always dont too, works great and it's easy
Old Mar 19, 2007 | 01:38 PM
NightShade's Avatar
I also have a reverse wire thats supposed to be hooked up to the reverse lamp, im suggesting for the reverse camera, can i just ground that too? looks like the wire diagram for my unit the brake and reverse wires are supposed to be hooked to get a signal from the parking brake light and reverse light so im gonna try to ground them both to a switch then the chassis, as long as the weather is nice here in maine.
Old Mar 20, 2007 | 05:20 AM
MPanova's Avatar
if you dont have a back up camera hooked up then there is no need to ground the backup camera wire, just leave it alone. ground the e-break wire and that should make it play when your driving
Old Mar 20, 2007 | 10:20 PM
NightShade's Avatar
hummm.. seems grounding it to the chassis doesnt work and hooking it up to the units constant 12v doesnt work and hooking it to the 12v for the cig lighter doesnt work either. so now i dont know what else to do but wonder how its supposed to be hooked up to the e-brake. help anyone? thanks.
Old Mar 22, 2007 | 03:09 PM
Scott8's Avatar
don't try to ground it to a power wire!!!!
