tC Tech and DIY Info for the Scion tC
Door Panel Removal
Old 12-31-2007, 04:02 PM
frame's Avatar
great diy.
frame is offline
Old 01-03-2008, 01:06 PM
dboyd4's Avatar
this is kinda off topic.... does the face plate for an automatic just pop off? I unscrewed the ****, popped off the little black piece and now I'm stuck- don't want to force it and break it....any suggestions?
dboyd4 is offline
Old 12-02-2008, 08:49 PM
TruAmbitionz's Avatar
I cant seem to disconnect the wires. Is there a clip I have to press or do they just pop out? I'm afraid to pull hard for fear of breaking something. I can't really see back there.
TruAmbitionz is offline
Old 12-02-2008, 09:16 PM
jwaggz82's Avatar
I believe there is a clip - use a flashlight and a mirror to see whats there ....and yea ....there isnt much room
jwaggz82 is offline
Old 12-03-2008, 01:52 AM
BZinn1's Avatar
are you trying to pull the panels.easy enough.
remove the sail piece by the mirror......remove the door close handle cover piece.....in the door open area is a small hatch open it and unscrew the screw.behind the handle piece is one or two screws ....do not remember but it will be obvious.....then pull.once you are free you will see the wires for the door locks and windows.......they are in a harness just unclip.and you are free.
BZinn1 is offline
Old 12-03-2008, 02:31 AM
j0hnBlaze's Avatar
watching*
j0hnBlaze is offline
Old 12-04-2008, 09:41 PM
Can I get a verification if there is a tab to push down before I pull? or Do i just pull?
I'm scared to go back in there again.
Old 12-05-2008, 01:12 AM
BZinn1's Avatar
yes the wire harness have tabs locking them in......paint to get at too du to the panel being in the way of seeing good.but yes there is a tab on the harness clips where they connect.
BZinn1 is offline
Old 12-08-2008, 05:14 PM
Streeter's Avatar
Bookmarkered
Streeter is offline
Old 04-22-2009, 01:35 AM
fuzzymica's Avatar
This was helpful. Thanks.
fuzzymica is offline
Old 10-06-2014, 05:04 PM
ottorod's Avatar
Default Excellent instructions! Thanks!
Originally Posted by ChefRaekwon
Hopefully this helps somebody out there. Once you get to the actual speaker your on your own.
Tools Needed:
1 Phillips Head Screwdriver
Flathead Scredriver
Your fingernail
Est Time:
10 Minutes at most
Step 1-- Start by prying off this door handle cover with your fingernail. Start at the top and work your way down. It does not take alot of force to get off.
Step 2-- Once you get the door handle off there are 2 Phillip screws holding the door handle in place.
One at the top
And one at the bottom.
Step 3 -- Move up to where the actual door lock is. With a flathead screwdriver pull the tab back. Once its pulled back unscrew with Phillips Screwdriver.
Step 4-- Thats all the screws now its time for the clips. Start at the far bottom of the front door. Just pull and work your way down. Theres probably about 15-20 clips. They pop out very easy and go back easy as well.
Step 5-- Disconnect the 2 power window/lock harnesses on backside of door.
What it looks like with the door panel off.
A look at the speaker.
Heres a look at all the clips.
ottorod is offline
idriveanxa
03-08-2015 12:03 PM
lunchbx05
12-29-2014 07:53 PM
Joeynenj
11-25-2014 05:29 AM
BlueBox
03-14-2008 08:54 AM
swtbabiboi4u
01-04-2004 04:03 PM
Quick Reply: Door Panel Removal
