tC Tech and DIY Info for the Scion tC
View Poll Results: Post a DIY
Yes
90.32%
No
0%
Dont Care
9.68%
Voters: 31. You may not vote on this poll
Shaved / Relocate / Hidden Antenna
Old 12-07-2009, 03:19 PM
grumpy6489's Avatar
Default Shaved / Relocate / Hidden Antenna
Hey Everyone,
As people requested I posted a DIY.
DIY: Shaved/Relocate/Hidden Antenna
B4:
after:
Tools Needed:
Flat Head Screwdriver
Phillips Screwdriver
Touchup Paint(in your car color of course)
Dupilicolor(Clear Coat)
Gloves
10mm Socket
Wrench
¾” Hole Plug(From Home Depot) $1.79
Sandpaper
Clear Waterproof Silicone
Pliers
Extra set of hands (at the end)
Size:  61.1 KBName:  DSC02171.jpg
First off you need to follow the instructions on how to remove the rear quarter panel from:
https://www.scionlife.com/forums/showthread.php?t=24346
just follow the rear till you get the passenger side done, that’s all you really need.
First off get the 3/4 “ hole plug and sand it down, after that take your touch up paint and just do about 2 coats. Get started on the prepping the hole make more happen with the time needed.
Remove the antenna you currently have on.
Take a flat head and turn counterclockwise.
You should be able to remove all the black rubber pieces, then after wards you are left with this.
Go inside of the trunk to where you removed the paneling, use the wrench and 10mm socket to remove the highlighted bolt.(Yellow) Also remove the wire cables that are connected to the right of bolt.(Green)
You should have this after its been removed
Go back to the hole plug, make sure it is dry, if so then do about 2-3 coats of the duplicolor clear coat. Let it sit and go back to the car.
Go check on the the plug, if its dry then your ready to go on. Take the silicone and add some to the teeth of the plug. You are going to do some wiggling and add force to get this in, trust me it fits. This is where you need a friend to help. Have the person push down on the plug so that it is as flush with the car as possible, while you go inside the quarter panel and take some pliers to bend the teeth outward. This will help prevent the plug from going anywhere. When you are done doing as many as the teeth, add a lil more silicone on the inside just to give that extra waterproof protection.
If you are one that does not listen to the radio then you are done, just put the interior back together. If you want to relocate and have a hidden antenna as I did then continue.
Take the antenna, and take the wire plug and switch it backwards so that it looks like this.
Then put it back in at an angle facing the taillight but angled more down. Like so. Then just rebolt it in. and you are done. Put the interior pieces back in and you have a hidden antenna. I have the same reception as I did when I first got the car. Hope this was helpful.
grumpy6489 is offline
Old 12-07-2009, 04:02 PM
scion_andrew's Avatar
i shaved mine off!
scion_andrew is offline
Old 12-07-2009, 04:06 PM
DJ08tC's Avatar
That looks good shaved.
man what offset are those rims, they look like +55 lol
DJ08tC is offline
how did u hide it?
Old 12-07-2009, 04:07 PM
i have no idea i have new ones now haha
Old 12-07-2009, 04:09 PM
DJ08tC's Avatar
yea i remember seeing the new ones.
yea tells us how you hid it.
DJ08tC is offline
Old 12-07-2009, 04:44 PM
AcidDrop's Avatar
looks alot better shaved.
AcidDrop is offline
Old 12-07-2009, 04:54 PM
iRPanda2690's Avatar
shaved = clean
no antenna to make your car look like an RC. lol
iRPanda2690 is offline
Old 12-07-2009, 06:18 PM
Cereal's Avatar
Originally Posted by iRPanda2690
shaved = clean
iRPanda2690 lol
if you can still get fm and am frequency go for it... can i have that s2k antenna when your done with it? imma go for shaving it!!!
Cereal is offline
Old 12-07-2009, 09:08 PM
grumpy6489's Avatar
Originally Posted by Cereal
iRPanda2690 lol
i was thinking on shaving it and just leaving it as is, but i decided to hide mine, mine is hidden inside the paneling of the car but underneath the orginal spot, i get perfect reception still.
Old 12-07-2009, 09:36 PM
so wat u use to cover the hole?
Old 12-07-2009, 10:08 PM
highvoltage1's Avatar
yea do a DIY for sure. It looks shaved. But then again its a FM tC so its hard to see what you did anyways.
highvoltage1 is offline
Old 12-08-2009, 01:00 AM
Cereal's Avatar
if it works and functional i say do it!!
Cereal is offline
Old 12-08-2009, 02:05 AM
t_urbo_C_harged's Avatar
watching...
t_urbo_C_harged is offline
Old 12-08-2009, 04:48 AM
grumpy6489's Avatar
how did u hide it?
how did u hide urs?
Old 12-08-2009, 07:30 AM
Cereal's Avatar
nice job!! bump for an awesome job for the ballistic matts... too bad i dont have to worry about an antenna for my xb since we dont have one sticking out lol
Cereal is offline
Old 12-08-2009, 10:38 PM
GQQSE13's Avatar
watching!
GQQSE13 is offline
Old 12-08-2009, 11:50 PM
tCjosh's Avatar
freakin andrew! answer everyone and tell them how you hid it!!!!!
tCjosh is offline
Old 12-09-2009, 05:20 AM
grumpy6489's Avatar
hahah i thought u were talking to me, but i do wanna know how andrew did his.
Old 12-10-2009, 07:02 PM
KAD
carbon_ninja's Avatar
hmmm nice diy
carbon_ninja is offline
Quick Reply: Shaved / Relocate / Hidden Antenna
