tC Tech and DIY Info for the Scion tC
Fuel Pump Install (Walbro 255LPH)
Old 05-17-2009, 12:36 PM
  #41
B_Real45's Avatar
Originally Posted by Fast_eddy
first i would really wanna thank the person wo wrote this DIY it was really helpfull on my install. i am new to this forum and im just amazed by the lack of motivation on some people to do thigs themselfs. i have no idea how much a walbro fuel pump install would cost but im sure more than 100 easy. its cool to drive a fast car but its cooler to build it urself.
i also had a question too. i noticed that since i did the install it takes a while to start the car and sometimes i even have to pump the gas a few times, is this normal?
Do you have to do this all the time or only the first time after install?
You really shouldn't notice a difference in start-up. I would recheck everything right away! The last thing you want is your fuel system to fail.
B_Real45 is offline
Old 05-17-2009, 03:12 PM
  #42
Fast_eddy's Avatar
i had to recheck ayways after a day i stop reading my gas level. i know my bad but everything is fine now . i was running 8 psi on stock fuel pump with 650cc injectors and e manage ultimate. now i got the walbro and im goin for a tune @ 12 psi ! my turbo is small so i dont think ill be able to crack the 300s
Fast_eddy is offline
Old 05-17-2009, 05:50 PM
  #43
B_Real45's Avatar
Good luck with your setup.
I was running 9-10psi on stock pump with a T04E 50trim and it was fine. In fact many people are running at lease that on the stock pump. I only changed mine for peace of mind.
B_Real45 is offline
Old 05-17-2009, 11:11 PM
  #44
Fast_eddy's Avatar
Garrett t3/t4 AR.60( non ball bearing) , cast manifold ( ebay ), stage 3 f1 clutch with fidanza flywheel, tial wg, hks knock off bov (for now), e manage ultimate, walbro 255, custom dp with direct pipe ( no cat at all ) 3 inch piping ( came with the car on a na set up..... Don't ask me ) , fmi with custom piping, I've never been dynod we street tuned the car its taking me forever lots of money issues but been boosted 6 months. I really want one those manifolds that are top mounted my fan keeps melting
Old 05-18-2009, 12:49 AM
  #45
B_Real45's Avatar
You need to get a blanket for you exhaust housing.. you can find them online for like $50 or so. Get some exhaust wrap for your downpipe.
B_Real45 is offline
Old 05-26-2009, 04:46 PM
  #46
Fast_eddy's Avatar
What I thought was the easiest part of my kit has been a big pain.... The walbro pump is longer so it hits the bottom of the tank , well the filter does and cause of this I don't get a good seal and fumes are getting in my car big time. I came up with a plan of using the handle of a hammer to make some type of dent on the tank giving me a little more room. Is this a good solution ? Or is not supossed to hit the bottom of the tank ?
Old 05-26-2009, 05:43 PM
  #47
B_Real45's Avatar
First I've heard of this issue...
B_Real45 is offline
Old 05-26-2009, 06:05 PM
  #48
ack154's Avatar
So... I was looking around to make sure this was actually in the Tech part of the site (it wasn't, even though the post was marked as Tech - but it is listed now)... and I cleaned up some of the immaturity.
You may now resume your regular discussion.
ack154 is offline
Old 05-26-2009, 06:46 PM
  #49
yamaha16bw's Avatar
Mine didnt hit the bottom of the tank.
yamaha16bw is offline
Old 05-26-2009, 09:17 PM
  #50
Crayola_G's Avatar
Yeah mine never hit the bottom of my tank either....somethings up. Try getting a new fuel pump housing? junkyard? our fuel pump housings probably similar to ones in other toyota sedans like the camry etc.
Crayola_G is offline
Old 05-28-2009, 11:36 PM
  #51
RusWolf's Avatar
will walbro help with making power without doing complete return fuel set up ?
RusWolf is offline
Old 09-12-2009, 06:07 PM
  #52
alienvictim's Avatar
just fyi, i did this mod. pretty good writeup.
on a side note if you trim the four tabs at the bottom of the walbro, than trim the grommet channel for the fuel filter out of the end cap of the housing it will fit without zip ties...... and will snap shut on its own.
thanks again for doing the hunting for this part. awesome since mine just went out.
alienvictim is offline
Old 09-13-2009, 05:45 AM
  #53
Renegade's Avatar
Thx again for this. =)
Renegade is offline
Old 09-14-2009, 01:56 AM
  #54
Crayola_G's Avatar
back from the dead!
Old 09-14-2009, 02:04 AM
  #55
Prototype_xB's Avatar
sticky!
Prototype_xB is offline
Old 09-25-2009, 02:26 PM
  #56
davedavetC's Avatar
im gonna bump this 1 more time, but would the install of a new stock fuel pump be about the same? or is it easier? just remove stock then put another stock on (reason i ask is i have 125k on my car and i think its time to change it before something happens lol
davedavetC is offline
Old 09-25-2009, 05:54 PM
  #57
Carlanga's Avatar
it's a lot easier though, take out, take apart, disconnect, re-connect new pump and all over again backwards. Pretty easy, I did the walboro in less than 2 hours. I'll post up pics of my work.
Carlanga is offline
Old 09-25-2009, 08:41 PM
  #58
mastertech86's Avatar
i've got the Ptuning kit which came with 550cc injectors and at 13 lbs a/f leans out toward redline so safe is 11.5 for me untill i get teh walbro =)
just in case, the turbo is a 57 trim .83 in the rear....
mastertech86 is offline
Old 09-26-2009, 05:48 PM
  #59
davedavetC's Avatar
is that in response to my question about the stock pump?
Old 09-26-2009, 09:27 PM
  #60
weezyfbayba's Avatar
is the wireing hard when installing this?
weezyfbayba is offline
Quick Reply: Fuel Pump Install (Walbro 255LPH)
