xB Tech and DIY Info for the Scion xB
Brake Rotor Install
Old 05-03-2007, 07:05 AM
  #41
tyrantcold's Avatar
i didnt want to hammer mine just cause i was using the scion car jack and i couldnt get the car high enought to jack stands under it. but yeah there pretty easy to remove after you give it a couple light wacks, i think Hawk pads or any other pads then what they came with would be better
tyrantcold is offline
Old 01-30-2008, 07:51 PM
  #42
sprslug_182's Avatar
I know this has been a while since this post was brought up, but as I was looking through it, I didn't see anyone mention that in order to prep the rotors for use, you first need to wipe the faces of the rotors with brake cleaner to get the film that is sprayed on before shipping. This is usually a must because it can glaze your pads and cause brake failure.
sprslug_182 is offline
Old 02-13-2009, 05:30 PM
  #43
GQQSE13's Avatar
just guessing but all scion brakes are about the same not matter whether tc, xb, xd, xa correct?
GQQSE13 is offline
Old 02-16-2009, 09:06 PM
  #44
365Motorwerks's Avatar
Cleaning the rotors is always a good idea, use some anti sieze on the lugs and follow the bed-in procedures from the pad manufacture, failure to do that will not give you maximum stopability.
365Motorwerks is offline
Old 03-14-2009, 06:18 PM
  #45
WhoKilledTheJAMs's Avatar
Good writeup-- I just replaced my pads and rotors (no upgrades or painting, though), and this was a huge help. Thanks, Scionlife!
A tip I stumbled upon-- the pads I bought came with new 14mm caliper bolts, so I used the old ones to push/pry off the rotor-- it seems to be that way by design. They're threaded for those bolts.
I really like the caliper design on these cars -- it makes brake service very easy.
WhoKilledTheJAMs is offline
Old 05-24-2009, 06:11 AM
  #46
Scion_Xb_44's Avatar
Default ABOUT UR MOON EYES
I REALLY DO LIKE UR MOON EYES , CAN U TELL ME WHERE AND WHATS THE PART NUMBER OF THE MOON EYES ID LIKE TO GET THEM FOR MY 2006 BOX
Scion_Xb_44 is offline
Old 10-07-2010, 11:28 AM
  #47
Styalz's Avatar
Thanks for the great write up
Styalz is offline
Old 12-04-2010, 11:07 AM
  #48
shastylz's Avatar
Default question
Whats strut and spring combination are you using blue strut and red spring? who make them
shastylz is offline
Old 08-28-2013, 09:45 PM
  #49
cameracar's Avatar
Are there any tricks to getting the stuck rotor free??
cameracar is offline
xBSciontist
06-18-2019 03:06 PM
TotalChaos
04-07-2015 09:02 PM
SuBSiN
03-13-2015 04:02 AM
Frustratez
02-26-2015 04:03 PM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: Brake Rotor Install
