Riding the clutch...
That is why you always want to get in the habit of using the dead pedal when cruising or not needing to change gears.... keep that foot away from the clutch when you don't need to use it.
Traffic is a killer for clutch-riding as well...
That is so true, I was in grid lock riding the clutch the other day
Originally Posted by slboettcher
What's the word on your tC?
Scott
Scott
Ummmm toyota is being stupid. They told me they couldnt hear anything even though i can and so can everyone else, they said they cant smell anything even though i can and so can everyone else, i asked if he visually inspected the belt..he said YES AND THERE IS WEAR ON THE OUTSIDE OF THE BELT! i then said WELL WHERE IS THAT COMING FROM!! he then said O WELL THE BELT HASNT SEATED PROPERLY AND IT TAKES TIME SO IT MIGHT RUB!...i was like BS! so i got ____ed and left!
sooooooo mad!!
when stuck in traffic neutral is your best friend, dont keep ridding the clutch to just move a few more feet. Also u guys might not know this but i found out a lil trick that helps somestimes, like if all u have to move is a few inches at a time just press the stick agaisnt the first or second gear slots without using your clutch and the car will begin to inch along. Just press it with sum pressure and i think what happns its the lil synchro things inside the gearbox start catchin partial gear. Just try it and u'll see what im talkin about.
Go to another mechanic and get a second (ok, 3rd) opinion.
Then, call Toyota and say you need to start mediation on this problem.
Scott
Scott
as you do it, you can watch the rpms slightly dip as the car begins to slowly roll.
i've heard of people starting off in second gear when in traffic, i'm not sure how that works though
honsesly guys theres is nothing to be scared about. ur just kinda pressing the shifter against the gear slot without using clutch, no grinding.
Scott
Scott
sooooooo mad!!
O sorry...im getting this wierd humming noise from i believe my serpantine belt tensioner. So they said they couldnt hear anything even though i can and so can everyone else...and they said there is actual wear on the side of my serpantine belt. THat's what i was talking about.
i tried to lurch the car forward by pushing it in 1st gear with the clutch all the way out. it moved forward slowly. i didn't want to push it any harder because i thought it would grind. it would work ok in traffic if it moved forward a little faster. i'll try again tomorrow
