RPM's and SHIFTING
when do you shift to 2nd and 3rd and forth. I normally just feel the car but recently I got curious that if i time my shifting with the right rpm would it be more effective?
5K RPM in 4th is a pretty high speed. I personally find that if I need some power getting around in local roads, 4K is adequate.
Shift points really depends on many things like Mightygnu said. I shift depending on the situation usually so I dont have any set shift points. Under normal conditions, I shift anywhere between 2-3K.
i shift at around 6300 - 6400 (07 tc)... this is for the first 3 gears... after that i just shift at around 4.5K... but if i dont feel like speeding up... then i shift before 3k. it also helps that i have a shift light installed so i know when im at/over 6300 rpm.
ive also read somewhere, i forgot where, but isnt the car equipped with "lift"? they were also saying that to stay in lift, you need to hit the right rpm at the redline or else you'll be out of lift... something like that. i know ive heard it from a couple of celica gts owners. not sure if the tc is equipped with the same thing. oh yeah, lift is like vtec but in toyota terms.
well if you need to pass somebody, i would heel and toe, and gear down....but for most daily driver situations, if you shift around 3k rpm for each gear, you're already going like 50+ mph....like for freeway on ramps, i usually will enter it in 3rd, and shift around 5000 rpm, and i'll be about 75 mph or so by the time i'm in 5th....and also, half of the time if i don't want to drive in boost, i use very light throttle and shift as low as 2k rpm, haha....
1. i cant beleive you installed a shift light lol
2. why do you take your car all the way to almost redline were after 57-5900 rpms is the peak power and TQ curve point of the car and from then on both curves just die off and your not making any more power..your just wasting gas... the 2az is not a honda were you rev high to make power all the way to the redline... it peaks then dies off (unless your on boost)
3. i do not suggest driving like this on a daily basis as you will burn up motor oil faster and run the risk of bending a valve or causing unwanted engine wear.
4. Also VVT-I for the 100th time DOES NOT RUN ON LIFT.. we run on timing... lift is not a factor in our motor unlike the VVTI-L motors.. theres no "staying in lift at the right rpm".. the only time the ecu give us more timing to alot us more power is at certain rpms and throttle positions. (which is why we tend to feel a decent kick in power from 3800-5300 rpms.. and from then on out the ecu pulls timing again, and we feel a loss in power in the upper rpms..
for simple daily driving...3k to 4k (inbetween this range) to save gas and get your self going and save gas! lol
for spirited daily driving 3.8k to 4.5 or even 5k rpms(inbetween this ranges) to reall have a little fun
for all out fun..shifting at 4500k-6k rpms lower gears and higher gears 6k ( u dont need the extra if your NA ur just wasting time)
for race 1st 5900, 2nd 5900, 3rd from 5500-6k 4th 6k,.. 5th 6200
save gas and motor oil... no need to tap the redline when your not making power..
for manuals shift hard at 5500-5900rpms and then shift close to redline.. you will see the car will chirp harder in the lower ranges i said then at redline..(why) because thats the peak point area were you are making the most power and not falling off the power/tq curve.
This is stolen...errrr quoted properly...from the "tC Owner's Manual Cliff Notes" Sticky
recommended shifting speeds -
1 to 2 or 2 to 1 24kmph(15mph)
2 to 3 or 3 to 2 40kmph(25mph)
3 to 4 or 4 to 3 64kmph(40mph)
4 to 5 or 5 to 4 72kmph(45mph)
maximum allowable gear speeds
1st - 47kmph(29mph)
2nd - 81kmph(50mph)
3rd - 125kmph(77mph)
4th - 172kmph(106mph)
Personally my shift points depends on my mood. If I'm bored I'll usually beat on the car and shift at 4k+. If I don't want to waste gas I'll usually shift around 2.5k RMP. Although I find it much easier and smoother to shift when I'm beating on the car.
1st - 47kmph(29mph)
2nd - 81kmph(50mph)
I'm sure you did read tha somewhere b/c........................... some uneducated tC ppl swear that VVT-i is definately similar to VTEC and it must be the high lift type. Not in this case, and not all VTEC has variable lift either.
yeah, the car feels boggy under 3000 rpms, but that was easily fixed with my zpi crank pully. i short shift all day and keep it near 2000 rpms where i get perfect response for lazily cruising around town. good for city mpg too.
Originally Posted by TCpete
oh snap.. finally.. some more smart people showin up on this site... about time! ^^
^^ same here.. at 2.5 the car just feels boggy and doesnt wana catch up.. i never shift that .. even on a lazy day ill shift at bare minimum 3100 around there..
I launch out of 1st gear between 3500 to 4000 rpm depending on what type of asphalt some roads are like sidewalk pavement than others are blacktops you can launch about 4K on that with very little tire spin. As soon as I get hooked up I watch the tach and shift at 6000 rpm every gear . Try it youll feel the difference. If you take it to redline you start to lose power. Especially if you hit the rev limiter. Try it out if you cant feel the difference learn how to shift.
Well basically if you are drag racing then I would suggest shifting pretty much at rev limit (around 6300 to 6400 RPM). Yes peak power is lower than this but the average power put to the ground will be bigger. This is how race cars setup their gear ratios. Basically you want to stay around the peak of the peak HP "hill" as much as you can (look at any stock dyno graph and you will see what I mean). This means you want to be on both sides of the peak HP "hill" so therefore you should shift after peak power is made. Now if you are just doing a little aggressive driving then do not worry about the tach but just focus on the feel and what is in front of you.
