Progress Technology Rear anti-sway bar tC xA xB
2004+ Scion tC Part Number: 62.2180 Adjustment Range: 3 hole End-links Included: Yes Size: 22mm Rear anti-roll bar Progress Suspension anti-roll bars dramatically improve handling. How? They minimize the traction-robbing body “lean” that rolls part of the outside tires off the pavement. Our Sport-tuned Anti-roll bars replace skinny OEM bars and rubber bushings with larger diameter (stiffer) alloy steel bars and polyurethane bushings. More roll stiffness means less body “lean”, and the tires stay flatter on the pavement (larger contact patches). The result is more grip and added driver control! Less body roll means more traction, faster cornering speeds, and increased driver confidence. Polyurethane bushings produce crisp response on turn-in. Progress Anti-roll bars are cold-formed in-house using our custom-built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place using a precise fixture for an exact fit.
TC: http://www.carcandymotorsports.com/p...roducts_id/141
2003-2006 Scion xB/xA Adjustment Range: None End-links Included: No Size: 22mm Rear anti-roll bar Progress Suspension anti-roll bars dramatically improve handling. How? They minimize the traction-robbing body “lean” that rolls part of the outside tires off the pavement. Our Sport-tuned Anti-roll bars replace skinny OEM bars with larger diameter (stiffer) alloy steel bars and polyurethane bushings. More roll stiffness means less body “lean”, and the tires stay flatter on the pavement (larger contact patches). The result is more grip and added driver control! Less body roll means more traction, faster cornering speeds, and increased driver confidence. Polyurethane bushings produce crisp response on turn-in. Progress Anti-roll bars are cold-formed in-house using our custom-built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place using a precise fixture for an exact fit.
xa/xb: http://www.carcandymotorsports.com/p...roducts_id/142
All in stock ready to ship.
Greg.
Originally Posted by carcandymotorsports
bump
