ScanGauge II -Only $154.95 Shipped! 12 Digital Gauges!
Works just fine on the 2005's
Will work on the 2008s
How 'bout "Works on ALL Scions, any model, any year." :D
This might be a good little gadget to have installed in my car while I ship my gauges off somewhere to do an LED swap.
Upgraded to "Lee's thinking about it/maybe after I pay off my credit card" status!
I think they are all drop-shipped direct from the manufacturer, so you will get the latest they are putting out.
They were supposed to be coming out with a "memory module" you could connect to the spare connector on the SGII. You insert a memory card (SD?) into it and then it would record the data from the SGII as you drive. Then you could download the info from the card into your PC and chart the speed, load, temp, etc. At some point, the firmware in the SGII was to be upgraded to handle this. Anyone with an older SGII would have to return it to be updated if they wanted to use the external memory. This talk was all from MONTHs back.
I don't see anything about this on their web page now, so maybe they hit some snags with doing this? I have no idea if the current shipping SGIIs have firmware to do this or not - but I am not sure I want/need the external memory anyway.
One thing I wish they would add is a BUTTON LOCK. The buttons are too sensitive and their either should be a lock to lock them out, or maybe just require a 2 second press to activate each one. I get my SGIIs all set like I want (MPH, RPM, MPG, and Water Temp) then I bump a button and have to cycle through all the gauge options back to the one I wanted.
Dennis
Dennis
Group buy going on!!
https://www.scionlife.com/forums/viewtopic.php?t=165592
It's $5 but still thats money that you could use for gas or food!! Or donating to a worthy cause!
It's not so much a problem with the ScanGauge not being able to read something as it is the Scion ECU not providing those readings to ANY OBDII unit. Hopefully someone with a tC will pop up and say which, if any, readings the tC ECU doesn't provide.
Tom
Tom
YES THEY ARE!!!
https://www.scionlife.com/forums/vie...r=asc&&start=0
Be the last one so we can get the order in!!!
Originally Posted by tCb00b
YES THEY ARE!!!
