Scion xB Carbon Fiber Hood (04-07) - In Stock!
Store Link:
Description:
Are you looking to complete your show car? Do you want to turn heads when you drive down the street? Look no further. The Scion xB Carbon Fiber Hood from Racing Solution is your answer. Made out of top quality carbon fiber material and a durable fiberglass body, this hood is a direct replacement to your stock hood.
The hood is a breeze to install. It bolts up to the factory latches and uses a strong hood latch so that hood pins are optional. *Note: Windshield washer nozzle holes are NOT pre-drilled and cannot be drilled by us.
Each hood is covered with a UV protectant clear coat to protect the hood from the elements. The purpose of this clear coat is to prevent fading of the carbon fiber material and to give the hood a clear, smooth finish.
When you place your order, our staff carefully packages your hood with several layers of bubble wrap. Each hood is mounted on plywood to protect the edges of the hood during shipment. The hood is then placed into a cardboard box and securly tightened. Your hood is picked up by FedEx and delivered directly to your door. After your order has been picked up, we will email you with your FedEx tracking number so you can watch your hood travel to your door.
Additional Images:
www.racingsolution.com..
the best thing of all i was able to go and pick it up WILL CALL here in CA...
ExtremeDimensions
Dec 18, 2014 04:47 PM
umnitza
Dec 1, 2014 06:26 PM
