Air Filter Cleaning / Recharge
make sure that you allow ample time for the oil to dry because i did'nt know that and put the filter back on in a matter of 30 mins. this messed up the mass airflow sensor and got some oil into the injectors. so the dealer graciously fixed it free of charge (because they did'nt know :D) they had to clean the entire intake system
Are you serious? Oil in the injectors?
Hmmm before ever reading this i cleaned my Injen intake filter with compressed Air.. i didn't think about damaging it... do you think that i may of damaged the cone and i should buy a new one.. i only have about 15k on the intake and filter.
Originally Posted by Nastos
anyone have a fujita cone? i never oiled it i dont know if i need to or not.
Cleaning the air filter is simple and can be done using soapy, lukewarm water, and let air dry. The Super Flow High Performance Air Filter™ contains a synthetic fiber that does not contain any oil.
if you can clean the filter about every 50k miles or 100k miles... how often do you have to change the filter?
and if you have to change the filter, do you have to use an injen filter for let's say the Injen CAI (RD2105), or can you use the K&N filter...
NEWS FLASH!!!
just read this thread over at the Lexus IS forums and found the info to be pretty helpful!
http://my.is/forums/f88/best-method-...s-ever-188702/
you get a bucket, use 2 scoops of Oxy-Clean (scoop included) then 3-4 liters of Soda Water (club-soda), dip your filter for about 5 minutes and watch all the dirt and grime float to the top!!
then repeat the usual steps of Air Drying and Oiling!
Cant wait to try this myself!
so after reading this thread i went to my pepboys and autozone stores none of them had the K&N one but they had the Speed by Spectre one the guy said it does the samething as the K&N one...i just want to make sure its safe to use with the Injen filter
