Seat Belt Warning (Disable Beeping)
I'm sure that some of you are annoyed with the seatbelt BEEP. If so this is for you.
This will work for all Scion / Toyota. It can be turned off. 1.) Power on (ignition on will do) 2.) Set trip/ODO to ODO (if its already on ODO you will have to cycle through) 3.) Power off 4.) Power on w/brake on 5.) (Within 6 seconds), press and hold the ODO for 10 seconds or more 6.) While STILL holding the ODO *after 10 seconds*, buckle BOTH seatbelts. Now release the ODO 7.) You will see in the trip display either a "b on" or "b off" 8.) Press the ODO to toggle between "b on" or b off" YOU WANT "b off" 9.) Now power off. If battery is disconnected, you may lose your setting. Default is always "b on" |
hahaha sounds like joke but even if it does work i cant see how it would be usefull lol and at any rate how i drive i think i need an extre seat belt for each passanger
It is not a joke. They always make you do stupid stuff like that. Usually it is not that complicated though lol.
this was coverd somehwhere else already if you do a serach you can find it also how to change the txt on your stero as well and to reset your windows and moon roof.
Neat. I added this to the Tech Section. I'll move it to the FAQ forum in a week or so. Thanks to stick_1NZ for the heads-up!
HAPPY BIRTHDAY MIKOCHU!!!!
OR YOU COULD JUST BUCKLE IT!
true....
Ive dont this to my tC, its annoying, and to those saying "OMG BBQ WHY DONT YOU JUST BUCKLE UP LOL OK?? HAR HAR". Usually when I am driving slow through the bank drive through that thing is annoying, or when Im gonna park my car. We all know we should wear our seat belts, but not all of us enjoy hearing the BEEP BEEP BEEP x10000.
This has been posted many a time...I turned mine off long ago :)
nice! i'll be doing it this weekend. driving 2 houses from the mail to my garage with a beep is annoying. (who walks when they can drive). lol
Nathan ycart1201 |
And correct me if I'm wrong, but it only beeps when the car is moving? |
up up down down left right a b a b a start select
Contra?
And yes it only beeps when its moving, I believe over a couple of MPH, still annoying none the less. |
Try moving a turkey and the seatbelt beep keeps on going off.
the more, the better :P
sometimes when i park my car i take it off a second before the car stops rolling --- i had no choice but to disable this ugly sound. .... the above steps work great ...only step i forgot was to plug the belt in at the end (which made me ____ed off cause i tried doing it like 20times before i gave up and went back inside to re-read the directions)
| All times are GMT. The time now is 01:10 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
