2005 Scion wiper problem
My 2005 Scion wipers started with intermittent problem as they would not work but every time I turned ignition switch on they would move approx an inch and then couple days later they started working now they have stopped again and do not move at all after starting up windshield, one of my mechanics thought I should change the ignition switch but I see that is not that easy so do I need to new windshield motor or switch
Hello billhodge! Welcome to SL!
You are in the Wrong Forum (Section) You are in the Introduction Forum and won't get any Technical Questions Answered Here.
It's not confusing at all. You go just below the Header ^^ SCION LIFE.COM and
Click on Forums and get a Drop Down Menu and Select the Forum for your Model car.
i.e. If you have a 2005-2010 tC: Scion tC 1G Owners Lounge - Scionlife.com
Or Select the Specific Sub-Forum in that Category
I believe there is a place in the tech and DIY section of the forum that contains maintenance and repair manuals. There will be more diagrams in there than you will ever need. If you cannot find it, let me know and I'll check the manual I have.
