iQ Tech and DIY Info for the Scion iQ
DIY Installation of iJDMToy 194 LED license plate bulb
Old 11-21-2012, 03:32 AM
surfcitylocal's Avatar
Default DIY Installation of iJDMToy 194 LED license plate bulb
The stock 194 Wedge bulb used for lighting the rear license plate on the iQ is not the brightest bulb (pun intended) so I changed it out to a 194 Wedge type LED bulb from iJDMToy. It's a simple job and the results are much better than stock.
The only tools you'll need are a flat head screw driver or a plastic trim removal tool.
The light bulb can be accessed from the under side of the rear bumper just above the license plate...
Using a flat head screw driver or a plastic trim removal tool, press on the black plastic tab located at the end of the lens and push towards the lens. The entire black plastic housing will be removed from the bumper, not just the lens.
When you have the housing removed, turn the bulb socket counter clockwise and the socket will come lose from the housing...
Gently pull on the stock bulb and it will come out of the socket. Replace the stock bulb with the LED bulb and turn on the lights to check that it lights. If it does not, reverse the bulb and try again. The LED bulb is polarity conscious and will only light if installed correctly.
Once you are sure everything is working properly, the installation is the reverse of the removal.
Here you can see the stock lighting...
And the difference with the LED bulb is clear to see...
An easy job but the result is well worth the short time it takes to accomplish.
surfcitylocal is offline
Old 12-28-2012, 06:26 PM
kingkevinn's Avatar
i swear i saw your car in el cajon, ca this morning. but i could be mistaken
kingkevinn is offline
Old 12-29-2012, 01:00 AM
It wasn't me but there is another iQ that looks very similar to mine. Same color wheels and graphics.
Old 02-01-2015, 08:40 PM
1FastIQ's Avatar
Default LED License Plate Light
Hi Taz,
I also installed one of iJDMToy's LED bulbs, and while it changed to color of the light, I didn't notice that much difference in the brightness over the stock light (been a while since I tried to attach photos, I'll now see if I can figure out the process again).
1FastIQ is offline
Old 02-01-2015, 09:22 PM
1FastIQ's Avatar
Default LED License Plate Light (Part II)
OK, now to see if I can add the plate photos from Photobucket...
Scion%20Plate%20Light%20121014%20002_zpseeodtvgu.jpg?1422829196987&1422829197485
Scion%20Plate%20Lighjt%20121114%20001_zpsvhktmvkm.jpg?1422829196987&1422829197484
1FastIQ is offline
Old 02-02-2015, 01:47 PM
Your original plate light looks much brighter than mine was. I do like the blueish tint, goes well with your body color.
Old 03-22-2018, 08:59 AM
Administrator
Administrator
MR_LUV's Avatar
Thumbs up
MR_LUV is offline
Dizie
04-20-2017 01:57 AM
Quick Reply: DIY Installation of iJDMToy 194 LED license plate bulb
