05 scion xb
Old Jul 23, 2012 | 08:31 AM
lunchbx05's Avatar
Default 05 scion xb
My 05 xb is about ready to turn over 93000 miles on it. i was wondering is there anything major i need to switch out. i have changed the spark plugs about 8k miles ago. i change my oil around 3k mark. i did not know if i should go ahead and change the coil pack and change the pvc valve or not. i also run engine cleaner through my car as well. Thanks for the help.
Old Jul 26, 2012 | 12:25 AM
jct's Avatar
jct
just the basic maintenance i always change out my pcv valve every year and rotate the tires
Old Jul 31, 2012 | 01:18 AM
RyanstC's Avatar
No need to replace the coils unless you have a missfire issue with them plus they are expensive, pcv, valve, and air filter as well as spark plugs are usually recommended every 30k miles also you may want to check your drive belts for cracks and wear and check the condition of the trans. fluid
ScionLife Editor
Dec 6, 2014 11:58 PM
ScionLife Editor
Nov 28, 2014 11:10 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
ScionLife Editor
Nov 20, 2014 05:20 PM
foxSCION
13
Dec 3, 2003 05:40 AM
