Anybody run a compression test 2AZ (tC or camry I4)?
Hi Y'all,
well after my many mis-shifts, I'm thinking it'd be a good idea to do a compression test--
I got myself a compression tester from autozone ($20). The instructions mention holding the throttle plates open in the carbeurator (I've read that you can just floor the pedal, but does this work since our cars are drive-by-wire?).
Also, it says to remove the high tension lead from the center of the distributor (we don't have one, right?) and ground it. It says to disable electronic ignition systems, disconnect the electronic ignition module or remove the primary battery terminal from the ignition coil.
Now, I'm assuming we don't have a distributor so i can ignore that step? ( I could be completely wrong that we do have one) I'm also assuming we have an electronic ignition system. If that's the case, where can I find the ignition coil? Is it easier to just remove some of the fuses pertaining to the start up systems?
I hope someone can help out--thanks in advance.
thanks for the comp. info-- i was gonna get to asking that but i couldn't figure out how to run the tests yet-- do you have any advice on the above questions? i'd really appreciate it
arinvolvo
Jan 21, 2004 11:40 PM
