Car show vacuum needed
Like it says, I'm looking for a vacuum I can use for pre-show detailing and take with me for last minute cleaning. Ideally something cordless would be better but from my research so far, I haven't found anything with the power I'd need without being a plug in.
the main one I'm looking at right now is the aptly named "Vac'N'Blo"
Vac 'N Blo Site
Anyone used this or something else that they found works good. Since it doubles as a blower, I figured I could also dry my car with it. At shows, I guess I'd need a DC/AC inverter and run it off the car for a bit.
Vac 'N Blo Site
I just use my normal household vacuum cleaner, with all the soft spongy, and long skinny attachments for getting at awkward bits, being super thorough & super careful not to scratch any plastic, including your engine bay. I usually vacuum the engine bay before I even start washing the car full stop, that way you're not making any mess in the engine bay.
So in answer to the OP, if you put a sheet of paper in the footwell on the drivers side (passengers too, if you're taking someone along), then remove the sheet of paper, that will lift out any mess in transit from home to the event. Kind of like the way dealers do when you have your car in for a Prestige service.
Oh, one tip that looks really nice is when you vacuum the carpet, try and vacuum in lines, so the pile is all going the same way, it will give the carpet a deeper look to it.
Hope that helps.
Hope that helps.
yeah, that helps, kind of what I do now. The rear is real easy to clean since it's all bamboo flooring. I'm probably the only one with a can of pledge in my detailing kit.
mmm.. lemony
I have neoprene seat covers, lint and pet hair don't stick. if it gets to dingy I just remove them and wash with wet suit shampoo. The only thing I'm having issues with are the floor carpeting in the front and the aftermarket carpet on the lower rear. I'll probably end up sueding the rear.
A blower would be nice for washing and the engine bay, I use my shop-vac for drywall and cleaning up sanding bits for body work, so it's filthy and wouldn't want to use it on the car.
rancur3p1c
Dec 19, 2014 04:30 PM
