Clay Bars
I have recently found the enjoyment of using a clay bar and how amazing the finish is afterwards. I will be waxing a my parents car and then a couple friends car and I wondering if anyone knows where to get just a clay bar? i have went to every autoparts start around here and they only sell the clay magic kit.
Try this place.
http://www.griotsgarage.com
thry sell the best window cleaner that I have ever used.
I have their clay bar and the porter cable kit and it works great.
Sooooooomth ___ paint.
I use Zaino Brother's Clay bar which can be found online at http://www.zainostore.com/. If you're going to a standard auto parts store, I highly suggest to stay away from the Meguiar's brand clay bar. Its much to soft and will easily rub off into the paint if you don't keep the painting surface lubricated. I've used a Mother's brand clay bar and that one seemed much better.
Is the clay bar good for getting bugs off?
Al.Truistic
aB
Al.Truistic
aB
it's fairly easy to do (just time consuming)... wash your car first... the lubricate the area (soapy water/quick detailer/etc)... rub the clay bar over the area until smooth to the touch... results are awesome and worth the effort...
how to:
Using a clay bar on Automotive paint.
as far as cheapest clay bars... i found this site:
http://detailplus.com/detail_supplies.htm
click specialty products... 8oz = $19.95, 5 or more $9.95... i haven't used them personally but its probably one of the better clay bar deals out there... can anyone vouch?...
how to:
Al.Truistic
aB
Al.Truistic
aB
here is a before pic from my tahoe drive
after clay bar and wax
Originally Posted by bBted
never use a clay bar before...how do u use it?
Damn that is great!
Is it easy to do a large area like the xB hood or the roof? I definitely will have to pick this up...Thanks!
Al.Truistic
aB
it gets spots and bugs off that normal scrubbing doesn't. you will be amazed by it.
Al.Truistic
aB
Al.Truistic
aB
Al.Truistic
aB
Check out Premium Auto Care http://www.premiumautocare.com They carry clay bars from all major manufacturers, including Meguiars, Clay Magic, Wolfgang, etc.
Here's the link to the Clay Magic bar:
http://store.premiumautocare.net/claymagredgr.html
Damn that is great!
Al.Truistic
aB
Al.Truistic
aB
I have used 2 different brands of the clay bar system. The frist was almost 5 years ago when i first had my Neon. I belive it was Clay Magic .. had a little pic of a cartoon clay bar with a cape on the front. The other was Mothers, both worked just great. In the first kit they gave a thin plastic glove for you to FEEL the before and after. Before you can feel little bumps and stuff like tiny grains of sand. Use the clay bar system, then run your hand over the paint again with the glove on and it was like moving my hand over glass.
Using a clay bar system removes all the embedded stuff in your paint like grit, chemicals, tree sap, bugs etc. It works great as long as you keep rotating the clay bar while you are using it. Do a small section and then kneed the bar till its fresh again. I do belive that after your done with the clay bar, you need to apply a fresh coat of wax. Not hard to do, just time consuming. Wash car. Dry car. Clay bar car. Wax car.
reviving a lost subject :D
i tried the clay bar bought the mothers clay bar kit it worked ok guess i didn't put much time in too it
but after i waxed it it seem that it got even more crap off my car
:D
but now i have a small dent in my hood, DAMN THOSE ACORNS!!!
Wash car
Clay Bar car
then... wash again before wax, or can you go straight to wax? Is the car "clean" after the clay? I know you spray the detailer on then rub it with the bar and then wipe it off, but do you need to wash it again? I sure hope not. I live in an apartment and we can't wash cars there, so every time I have to go somewhere else is a fairly large PITA.
Clay Bar car
You can either wash again before waxing, because sometimes people don't get off all the detailer spray/ soapy water. Personally, I just wax right after claying. I just clayed and detailed my bsp xB a week after I got it. I did a better job than the dealer. I'd love to show pics of my car, but I don't know how to post them. Anyways, I recomend clay baring. :D [/img]
