Cleaning your tC's engine bay?
Old Apr 28, 2006 | 06:02 AM
magnetic's Avatar
Default Cleaning your tC's engine bay?
You guys have a special process for cleaning the engine bay? Like, special preparations that you guys do before taking your hose to it?
As much as I don't really open my hood, I know that my engine bay is pretty filthy. It's an eyesore whenever I want to show off my intake and whatnot.
I know that there should be certain parts that should be covered up with a plastic bag or something, but I'm pretty chickenpoop to wash it at all. Any pointers?
Old Apr 28, 2006 | 06:16 AM
Kilo6_one's Avatar
i use simple green, butyou can use a degreaser like gunk.........and make sure i put saran wrap or plastic on everything electric..
i spray alot and i mean alot of simple green to the really nasty areas then let it soak in then spray it off.
Old Apr 28, 2006 | 06:18 AM
eujin's Avatar
^ the man speaks the truth. cover EVERYTHING electrical before you degrease and hose down. if you are unsure of your work after hosing down, leave the hood open for a little bit on a sunny day to dry things out. good luck on cleaning.
Old Apr 28, 2006 | 06:22 AM
Kilo6_one's Avatar
most of the electrical stuff is pretty well shield anyways, but its better to be safe then sorry.
Old Apr 28, 2006 | 05:43 PM
nadir's Avatar
yeah ... everything electrical needs to be covered.
I much prefer to just do everyhing w/ a wet rag now. I'm a little ansy when it comes to spraying the entire engine bay w/ water like I've seen many do.
I've also read about how ppl screwed up the electrical systems too doing that. No thanks
Old Apr 28, 2006 | 05:46 PM
Kilo6_one's Avatar
usually i go to a freind who has a steam cleaner, which works awesome.........no actual water just high compression steam.
Old Apr 30, 2006 | 05:49 AM
Neothin's Avatar
werd ^
use the steamer to break everything up and then just take a quick pass with a towel to get it all up and out of the engine bay.
Old May 5, 2006 | 03:11 AM
PhotoKyle's Avatar
My process is to cover anything electrical, or anything that looks like it wouldn't having water sprayed on it. Then I spray every exposued part with Meguiar's Safe Degreaser or Super Degreaser, depending on how dirty the engine is (both are part of their Detailer line and are only available in 1 gallon jugs). I let it sit for a minute or two, then agitate the really dirty parts with a brush, towel, or my hands (covered with gloves). I rinse off with a pressure washer (I use the widest spray pattern, and keep it a couple feet away from the motor, and I never spray a certain area for any extended period of time). I finish it off with Meguiar's Hyper Dressing, diluted 3:1 (again, only available in one gallon jugs).
This isn't a tC, obviously, as I've only had it for 300 miles so I haven't detailed the engine yet. This is my old XRunner...
Old May 5, 2006 | 04:29 AM
Neothin's Avatar
sorry for going a little OT...
try using some of that hyper dressing in the wheel wells and on the rubber door/hood/hatch seals. i've had great results :D
Old May 5, 2006 | 04:38 AM
PhotoKyle's Avatar
I love Hyper Dressing for wheel wells. I also used to use it for my composite truck bed.
Neothin... that user name sounds familiar, do you frequent MeguiarsOnline and/or Autopia?
Old May 5, 2006 | 04:45 AM
Neothin's Avatar
yep, im an autopian :D
Old May 5, 2006 | 08:42 PM
FromThisSoil's Avatar
Meg's Online representin' w00t w00t!
Old May 6, 2006 | 01:54 AM
magnetic's Avatar
So, off the top of my head, I'd probably want to cover up:
- the battery terminals
- fuse box
- the area where the coupler is on my Injen CAI
- where the intake is inserted around the throttle body (not sure if that's necessary =P )
Am I missing anything? I probably am.
Old May 12, 2006 | 02:58 PM
brownbanana's Avatar
clean engine bay up there
Old Jun 24, 2006 | 07:06 PM
soGone's Avatar
- COVER THE ALTERNATOR!!!!
Old Aug 23, 2006 | 03:27 PM
fastandcurious's Avatar
nice thread. i plan on washing on engine bay soon so this definitely helps. thanks!!
Old Sep 1, 2006 | 06:25 AM
Kilo6_one's Avatar
try peeing on it, its better then any soap i have tried..............
Old Sep 1, 2006 | 06:52 AM
bBlover's Avatar
PhotoKyle, that's one hawt X-Runner!!! Why'd you get rid of it?? I say use a steam cleaner.
airmankevin1
Feb 14, 2018 01:23 PM
carid
Mar 30, 2015 07:08 AM
Halo19boy
Jan 27, 2015 10:19 PM
Besk_one
Nov 17, 2003 09:28 PM
