Front Differential Oil?
Old Mar 4, 2005 | 05:12 AM
shangtsung's Avatar
Default Front Differential Oil?
What is the Front Differential Oil that needs to be replaced in addition to the manual transmission oil?
___
Old Mar 4, 2005 | 08:30 PM
IBJanky's Avatar
Default Re: front differential oil?
Originally Posted by shangtsung
What is the front differential oil that needs to be replaced in addition to the manual transmission oil?
i wasnt aware than scions had a "front differential"
Old Mar 5, 2005 | 05:47 AM
shangtsung's Avatar
Page 7 of the scheduled maintenance guide, at 30k miles:
Replace front differential oil
Replace manual transmission oil
Tighten nuts and bolts on chassis
Old Mar 5, 2005 | 06:46 AM
crayonBOX's Avatar
that's just like "tighten nuts and bolts on chassis"...
there are no `real` nuts and bolts they need to tighten... millions of cars go without that kind of care...
Old Mar 5, 2005 | 07:02 AM
shangtsung's Avatar
millions of cars don't have that listed in their maintenance guide either....
Old Mar 5, 2005 | 01:16 PM
Derk-xB's Avatar
That's a poor argument...
Shang - what's your question? Are you asking what kind of oil to use? Are you asking what the oil is?
The manual will tell you the range the oil should be (75w-90 or something). The oil is essentially your transmission oil.
Old Mar 19, 2005 | 09:11 PM
shangtsung's Avatar
It's listed as a separate item but I only found one drain plug and one fill plug on the transmission case.
Old Mar 19, 2005 | 10:10 PM
boilerman's Avatar
Might check the lug nuts. I once had a rattle develop in the front left of a nearly new Ford Ranger. One of the lug nuts had backed off completely. I had a truck deposit a rim and tire in my yard as he passed one time. A very shook up felow.
Old Mar 19, 2005 | 10:21 PM
chadfo's Avatar
Does anyone know the capacity of the transmission. I want to change mine and don't know how much fluid to buy.
Old Mar 19, 2005 | 10:24 PM
jct's Avatar
jct
thats an easy one just keep filling it up untill oil starts coming out of the fill hole, welllllllllll if the fill hole is on the side that is
Old Mar 19, 2005 | 11:37 PM
Derk-xB's Avatar
Tranny fluid should be bathing your differential as well.
Capacities should be in the manual, right? Fill-to-spill is a good rule of thumb, just make sure the car is level.
Old Mar 28, 2005 | 07:44 AM
Rion's Avatar
It's a front wheel drive car.
We have transaxles, which means that, with the manual at least, the differential and transmission are in the same case, it's like one piece. Differentials and manual transmissions both use gear oil. You can find it at any auto supply store.
Old Mar 28, 2005 | 08:52 AM
bB384's Avatar
IV ACE
Actually I was planning on doing this sometime this week so I might as well ask now...What viscosity should we use? whats the capicity? And where is the fill plug?...on the Manual tranny of course. Thanks in advance!
Old Oct 16, 2021 | 04:08 PM
JSR07Racing's Avatar
The actual amount is 2.6 quarts
Old Aug 24, 2024 | 08:03 AM
Nick_93's Avatar
Straight on subject! Thanks!
DougC
Feb 22, 2015 02:39 PM
stuUNGAR
Jan 1, 2006 06:41 PM
Kumitsu
26
Mar 31, 2005 04:54 AM
brarsandeep
Aug 26, 2004 02:08 PM
djct_watt
Jun 30, 2004 06:32 PM
