Gear Oil Change
Old Jun 8, 2014 | 04:51 PM
pbullis's Avatar
Default Gear Oil Change
I am wanting to change the manual transmission fluid in my 06 tc. Now, ive heard that gear oil is what i need to put in it, but ive seen manual transmission fluid. I was going to go with royal purple 75w90 gear oil. Is this what i should use I've also heard to use redline mt-90 oil. Is gear oil what i should put in my transmission?
Old Jun 19, 2014 | 03:05 AM
GammaTNT's Avatar
http://www.amazon.com/dp/B002GI42DU/...332190_TE_dp_1
I am using Eneos 75W-90
Old Jun 19, 2014 | 02:10 PM
pbullis's Avatar
Originally Posted by GammaTNT
Goodluck.... I have up because the reverse sensor is a 1-1/6 bolt, after buying that and getting back home and jacking my car up again, busting my knuckles because the reverse sensor is in with like 42655955568541lbs of torque. Then, got under the car, and the drain plug is like a 1inch, and I couldn't find my open end wrench set, and a socket don't fit in between the plug and the frame. Almost started to round it off trying to use a pair of pliers then a Cresent wrench. Good luck man.... Haha maybe I'm just retarded
voodoo2crue
Mar 18, 2015 01:30 AM
cid_mcdp
Jan 5, 2015 02:45 PM
DJ_OVERGOLD
35
Sep 8, 2004 05:28 PM
scionman2003
19
Feb 26, 2004 02:55 AM
BlueBox
22
Nov 7, 2003 08:18 PM
