Which grade of gas are we suppose to fill?
Originally Posted by George
Originally Posted by scion
The amount of octane in gasoline has nothing to do with how "explosive" it is, all octane ratings provide the same amount of oomph. The octane actually delays the speed of combustion... so the more octane in the gas the longer it takes to completely burn.
Engines are designed to work on a specific octane rating... the ignition timing is set for it. If you use a high octane on a car designed for a low octane you will decrease the performance because the burn won't happen until the piston as past the regular point of ignition. Bam -- loss of power and efficiency.
If the manual says 87, stick with 87.
I stay away from ARCO though, my car actually runs worse on it for some reason.
Darren
Darren
Octane is a hydrocarbon compound with 8 carbon atoms, hence the "Oct" prefix.
Heptane is a hydrocarbon with 7 carbon atoms, hence the "Hept" prefix.
(for petroleum engineers, yes there are more technical names for these, but let's keep it simple!)
You mix these two compounds to get standard fuels of various octane ratings. 50/50 heptane/octane gives 50 octane, 20/80 gives 80 octane, and pure octane is 100 octane.
These chemicals are rather expensive and you wouldn't want to bear the cost of running them in your car.
Fuels are tested in a test engine. The test engine is actually run by an electric motor for consistant speed. The neat thing about the test engine is that the head can be screwed down to vary the compression ratio. The engine is run on the fuel to be evaluated and the head is screwed down until the engine starts to pre-ignite or "ping". The setting is noted, and then the test is repeated with various mixtures of heptane/octane ("standard fuels") until the same point of pre-ignition is reached. The percentage of octane in the standard fuel that produces the same pinging behavior is the octane rating of the fuel.
What is pre-ignition? Simply having the fuel ignite all by itself without the intervention of the spark plug. You don't want this to happen, as the fuel burns all at once, causing very high pressures in the combustion chamber which can break things. The higher the octane rating, the more resistant it is to pre-ignition, and that is really the only difference that octane makes. High-octane fuel has a slightly smaller flame propogation speed than low-octane fuel, but not enough to make any difference in a real-world engine.
Toyota specifies that they have designed the Scion engine to run on 87 octane fuel. If that is truly the case, you will not get any advantage in running 91 octane fuel.
Nevertheless, some claim that they have better performance or mileage with 91 octane. How can that be? Well, one way this could happen is if they had a tankful of "bad" 87 octane that was actually lower in octane. The engine's computer would adjust the engine to run on the lower octane fuel, resulting in lower mileage and performance, but not doing anything permanently bad. When the person fueled up with 91 octane, the computer simply readjusted to the normal 87 octane specs and produced better performance and mileage.
Another scenario is that Toyota pushed the envelope a bit with the engine computer, which means that the engine actually does benefit from higher octane fuel. There's nothing magical about the number 87 and they might well have designed it for 87.5 or 88.
How do we tell for sure? All we need to do is to get a Scion, put fuel of a known, measured 87 octane in it, and run a set schedule on a test track. fuel the same car up with 91 octane and run exactly the same schedule on the same track. The results will be quite clear.
Another way to do it is for someone to keep long-term records of a vehicle in regular commuter service. The quirks in the data will tend to average out, so comparisons can then be made between the fuels.
For those who feel that one brand of gasoline is better than others, be aware that all the refiners freely trade gasoline back and forth with each other to meet the needs of their retailers. That "high quality" Union 76 fuel you are putting in your tank may well have come from an Arco refinery!
George
After reading some info on this thread, I've decided that I will try 87 octane at the next fill-up and post my results. Also, I am running stock wheels/tires/suspension with 32 psi tire pressure at all 4 corners. If I don't see an improvement after running 87 octane, I will boost pressure up to 37 and see if that makes a difference.
If I still get the same 27 mpg, I will go to the dealer and have them check the engine.
Cheers
Guys... comon...... I am confident in your essay writing abilities and facts but this is crazy.......although thank you for the info, I was actually thinking about this topic last weekend.
i'll toss my 2 cents on this subject...
i have an stock auto xB that i run about 50 miles each day, almost all freeway, little to no traffic, averaging 65-80mpg, with a short uphill climb (for those who drive 680 in the bay area, that's the sunol grade)... my first tank was straight from the dealer (unsure of the octane rating)... and averaged 30.9 mpg... (which i was already stoked about coz' i was drving my xterra on the same stretch and got 19 mpg)... i filled up with 76 supreme (91 octane) and got 35.1(!) mpg, which blew me away...
granted, my car is new, and is prolly just getting broken in which might explain some of the improvement, btwn the 1st and 2nd tank... but i never expected to actually exceed the manufacturer specs...
on my 3rd tank now, and it seems on par for the same results... i'll post if u guys want (not much else to think about when driving my box an hour a day, lol!)...
i read some ppl on this board drive 100+ miles per day... any additional insight on the subject?..
My girlfriend lives in Fremont, and I go over the 680 Sunol hill all the time(gotta get a running start!). I hit my all time high of 35.3 mpg last weekend with about 90% freeway, no traffic, no A/C, 70-80 mph. Although, it was right after my first oil change, I don't know if that helped.
My xB is stock auto, and I always use Arco 87 (cheapest and closest to my house). For regular driving, i drive about 30 miles a day in stop/go traffic, and I've never gotten less than 29.8 mpg
good article on kbb.com about when to use premium:
http://kbb.com/kb/ki.dll/ke.kb.sp?kb...;article/Ralph
I drive a 2k Civic HB, so its got the god awful sohc nonvtec D16y7 :/. Even though the motor is recommended to run 87 I still run premium. I commute everyday about 45 miles, and it is completely flat (South San Francisco -> Emeryville) During the week I hardly put any city miles on it since work is but a few blocks from the offramp and I try not to do much excess unecessary driving. After running the commute for about 4 weeks averaging 330 miles per tank on regular (until the gas light went on) I decided to give premium a try since gas prices have finally dropped down. I now can go rounghly 375mpg with premium before the light turns on. now for me that is great since the roughly 45 miles extra per tank would add up to roughly 1 saved tank of gas per 2 months(roughly). So 6 tanks a year. But figuring how it does cost me a little extra I'll say 5 tanks per year, or roughly 100 bucks (round $20 a tank). Now I could figure this to be a by product of the increase in airflow to my engine due to mild modifications, i.e. intake, exhaust, header, and that the increase in airflow would allow me to burn the higher octane more efficiently. But who knows, that is just wat I have found in my 2 month study( 4 tanks reg, 4 tanks premium). Also I have read many articles stating that octane from pump is usually lower than advertised, not by a whole lot but u know, anything makes a difference.
I'll pony myself up for this. I drive 150 miles a day for my commute. Generally not as much traffic as I leave later in the day. I'll try to drive conservatively and see what I get with 87 octane & 91 octane. Unfortunately, it is a rough science as any variation in the following can affect results:
Different gas stations
Different pumps
Different weather conditions
In any case, I'll fill up with Chevron 87 then Chevron 91. I'll try to use the same pump so when filling up the automatic stop will give me similar results in volume.
I'll probably be able to reply to this next week. My traveling is going to be all over the map this weekend, so now wouldn't be a good time.
To be honest...I doubt I will see much difference other than about $2 more in fuel costs.
Different pumps
Different pumps
Different pumps
i have been running 89 octane in mine since i got it and was wondering how it would do with other grades.....
The guy who sold me my Scion was telling me something along the lines of, if u put in a higher octane than 87, in time some kind of deposits will collect in your gas tank. I honestly can't remember what he said exactly, and even he didn't sound THAT confident about it, so i dunno.
I hear this all the time! Putting in higher octane does NOTHING for gas milelage. Higher octane is just fuel more resistant to detonation. The compression of the Scion is 10.5:1 which could call for high octane, but it's tuned for 87 octane. The only thing higher octane will do is keep your car from pinging. But the Scion doesn't have detonation problems with 87 octane, so there's no point to using higher octane unless you have extensive mods or high milelage. There's nothing anyone can say that will make high octane=higher milelage per tank. I've heard so many people make this claim which is very misinformed. My buddy is a tech at Honda, and he hears customers (mostly ricers) say that about their Civics all the time. He just laughs at them. Read up on the subject. Maybe you just think you're getting better mileage because the gas is more expensive and you're driving more conservative. Maybe the weather was better. Maybe you went up fewer inclines. Maybe you caught more green lights and drove on the freeway more. Maybe you recently installed i/h/e. Maybe you carried less people in the car. Get what I'm saying? There's too many factors for anyone to make this claim. I trust the lab studies more than what anyone says they have done on a few tanks.
as for octane and power, i noticed when i had my 96 Sable [6 cylinder] that the engine felt stronger with a higher octane fuel....i could feel the difference in acceleration between the two....
in my xB, i have been using 89 since i got it thinking i might get a [b]little[/]more power from a higher octane gas.....
i would like to try 87 but i am concerned about starting to use it now since i have been running 89 all along....
any thoughts on this would be appreciated....
How many miles are on the Sable? Older cars usually do get more power from higher octane due to the carbon deposits raising the compression. On newer cars it shouldn't make much of a difference if any.
higher octones wont make any difference on gas mileage...
some guy in our accord club dyno the car using different octanes...it shows 87 out perform higher octanes...so if the car is design to use 87 then use 87....
This could be mental but the only thing i have noticed is that when i stopped using 87 and went to 89 the engine idles smoother. At 87 it always seemed like it wanted to stale. After all at 10.5:1 compression seems aweful high to be running cheap gas. Yes I know its tuned for 87, but geez, 10.5:1. Does timing affect it that much that you dont have to run super? Especially under heavy throttle?
I do agree with Darren. Stay away from ARCO, or at least the one by my house. My cars run horrible on it.
It shouldn't effect the way the engine runs because the ECU will adjust timing to make the car run exactly the same whether it has 87 or 91. My xB runs just perfect on 87.
as far as mpg, w/ the Injen intake, Tanabe axle-back exhaust, 2" Spy drop, and 17" wheels, I get just over 30 mpg doing 80 mph on a 54 mile one way commute. now that I've had the intake and exhaust modded, my mpg has gone own due to the lead that has settled in my right foot. oh, and I have a 5 speed.
I usually average 34-36 mpg when I keep it at 70 mph.
squirrel
squirrel
