HELP!!!!!!!!! Splash paint
Old Nov 13, 2005 | 10:09 PM
bdballer69's Avatar
Default HELP!!!!!!!!! Splash paint
today i was washing my car, and i found a lot of small white paint splash marks all over the front side and the passenger side skirt of my car...i tried using alcohol...which is close to useless on removing those paint marks, unless i scrub it real hard, some will come off.
Anyone know what i can use to remove those paint? Any useful comment will be welcome thank you.
Old Nov 13, 2005 | 10:31 PM
baileyw813's Avatar
Just get some goo gone.. the yellow (citrus-smelling) liquid. I used some on my car yesterday to get some annoying paint from the fresh white lines just painted in the road. came off real quick. should work just fine.
Old Nov 13, 2005 | 10:48 PM
bdballer69's Avatar
i tried that as well...did you let it sink sit there for a while be you wipe it off? or just spray and wipe
Old Nov 13, 2005 | 10:53 PM
toastbox's Avatar
A claybar should remove that and just about any other contaminants on your paint. You'll want to apply a coat of wax after you clay, but your car will look spankin fresh
Old Nov 13, 2005 | 11:15 PM
boostedscion's Avatar
yea claybar would be good
Old Nov 13, 2005 | 11:31 PM
bdballer69's Avatar
excuse my ignorant...what's claybar? And will it hurt the coating of my car's paint?
Old Nov 14, 2005 | 01:17 AM
toastbox's Avatar
A claybar is an item that is used to remove contaminants from your paint. You can get them from any Autozone/Pep boys type car parts store. It is actually *good* for your car, so no, it will not hurt your car at all, provided you follow the directions.
Here's a few links that will give you some advice about how to use one (second link is a vid):
http://forums.bimmerforums.com/forum...hreadid=113673
http://www.adamspolishes.com/videos/clay_bar.cfm
and here is a link for exterior care on your car:
http://forums.bimmerforums.com/forum...hreadid=158378
Old Nov 14, 2005 | 03:11 AM
bdballer69's Avatar
wow..thanx alot...the video helps alot....i ma get myself some claybar GOOD POST!!!
Old Nov 14, 2005 | 03:38 AM
toastbox's Avatar
very welcome! let us know how it turns out
Old Nov 14, 2005 | 03:48 AM
GT4Dreams's Avatar
don't use laquer thinner...
Old Nov 14, 2005 | 04:42 AM
808flintscion's Avatar
or gasoline..
Old Nov 14, 2005 | 04:07 PM
THansenite's Avatar
I had a can of construction orange spray paint get on my car. The can dropped out of the back of a construction truck, top broke off, and sprayed my car. I have tried using a clay bar and it did nothing. Are there any other recommendations for removing paint?
Old Nov 14, 2005 | 04:17 PM
toastbox's Avatar
spray paint and street paint are two different things...i dont think a claybar will remove spray. good cleaner wax might though. if that doesnt, then maybe take it to a paint/detailing shop, they might be able to help you.
Old Nov 14, 2005 | 04:48 PM
rpgonzalez's Avatar
I have had very good luck with nail polish remover. Its amazing how it removes everything BUT the OE paint. Make sure to reapply wax/polish
Old Nov 14, 2005 | 05:03 PM
schwettynuts's Avatar
Acetone will remove the spray paint plus your car paint. I guess you can use it if you are desprate but I dont recommend it. Everytime I see a paint spot I use my nail and I can usually remove it.
Old Nov 14, 2005 | 09:24 PM
NightRider202's Avatar
try going down to a paint store, like sherwin williams, they have a solvent called "goo gone", or something like that. it worked well for some exterior paint overspray back in the day. try that, but ask the employees just to make sure it won't hurt your car's paint.
Old Nov 15, 2005 | 01:53 AM
gimpdaddy's Avatar
Go to your neighborhood Sherwin-Williams. Ask for a product called "Painter's Pal," I believe it's called. Read the back carefully, but I think it'll take latex paint off without damaging the car's finish. Don't hold me to that, though.
I work for SW, and I'd check, but I'm out at my store right now...
Old Nov 15, 2005 | 02:11 AM
natodog's Avatar
Default Re: HELP!!!!!!!!! Splash paint
well me and my grandpa used brake fluid to get the paint off an it work perty nice, old family secret.
Just kidding, dont use brake fluid
Old Nov 15, 2005 | 03:27 AM
bdballer69's Avatar
you are absolutely right...don't use nail polish....use rubbing alcohol instead...i tried it on my car...it kinda work...but i have to rub real hard.....and use alot of it......so yea....i am still hoping claybar will do the trick, when i have time i'll go get some and see how it turn out....
how much and what brand should i get (claybar)?
Old Nov 15, 2005 | 03:30 AM
bdballer69's Avatar
goo gone don't do jack...i tried that, and it's worst than my rubbing alcohol...and plus goo gone is only use for removing "goos" i used it to remove sticky tape marks (expired tapes...yes i used expired tapes...) on my window after Rita, works wonder... but as for paint...no don't anything cept making your car smells good with that citrus smell
