Instrument Panel Lights not working
Old Jan 20, 2016 | 01:48 PM
Rob54Monty's Avatar
Default Instrument Panel Lights not working
Speedometer, clock work, fade with fader, yet the temperature dial, air flow dials, and the electric mirror selector motor button switch lights are not working.
So the dash is dark as can be at night, radio has its own dimmer inside it.
I do not recall these lights ever working since i bought it used.
Ive read they are possibly on the same fuse as the tail lights, well they work.
So, I see new bulbs can be bought, and will do that, yet I wonder if there is some other possible reason to look for when i get to doing this.
I had read someones steering column somehow cut the wire that runs these lights and kept grounding out and burning out the fuse, but again, my tail lights work fine and will inspect fuses also just for the sake of it.
Its 17 degrees out, so before i head out to do this, id like to have a good idea of everything to look for.
Its an 06 XB so, id imagine they do burn out after time... I just find it odd that that are all out. I am unsure if the fog lamp switch is suppoed to be lit, its after market lights with a switch from the junk yard. I put my own radio in and may have forgotten a gang plug wire harness, but again, it did not work when i bought it, stock radio was there and looked as if it had never been changed out.
Thanks for any ideas you may have...
Old Jan 21, 2016 | 03:18 AM
sithscripter's Avatar
What a coincidence ... I replaced my center console bulbs tonight. On my '04 xB, the climate controls are backlit by two redundant bulbs behind a plastic light pipe, so chances are that one fizzled out ages ago and the other just went last week. Part number for mine was 90010-01082.
Those are on the same fuse as the speedometer/clock/etc.
And don't worry about the power mirror control ... IIRC that isn't lighted.
Old Jan 21, 2016 | 01:20 PM
Rob54Monty's Avatar
Thank you, good to know, finally someone sent a reply to me on this site, ha hah...
Really cold out, but soon as it breaks, im gonna put some new ones in!
Blessings!
Old Feb 29, 2016 | 02:54 AM
curls's Avatar
Blessings!
Are there any active sites out there?
It's not even that cold any more, lol.
SloTC1
Apr 2, 2015 07:11 PM
tcer904
Regional - Southeast
Mar 19, 2015 08:59 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
MaxPower
Oct 22, 2003 09:22 PM
