Little Help Here Pls.
My 3rd gear went out. 2nd gear slams in hard most of the time. Since 3rd went out. Going from 2nd to 4th makes 4th hard to grab sometimes.
can also hear from outside the car when going from N to R it slams hard. I have a 08 5 speed.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Nov 9, 2020 at 06:21 PM. Reason: Moved to Correct Forum by Administrator
What is the question?
Sounds like you need (at the bare minimum) new synchros inside your tranny. Might be easier/cheaper to get a rebuild or junkyard tranny and swap it in (usually a good time to upgrade your clutch/flywheel at this time). I would also take a look at your motor mounts to inspect for tears.
You should drain your transmission fluid and see if there is any metal shaving or pieces in the fluid. Sound like 3rd gears teeth are gone and forth possibly on its way out., and the synchros are probably damaged.
When you skipping to 4th gear from 2nd, are you revving higher (4k-5k RPMs) that you would to shift normally or shifting as you would normally when shifting to third (around 3k RPMs)? If not you, probably should be in order to engage 4th properly. You could also inspect the shift cables so see if there damaged.
xroad2oblivionx
38
Aug 28, 2008 05:57 AM
