need to know something bout oil change quickly
I was told the tC takes 5w 30? the manual says something about 0w 20 and 5w 20?
so what is right? i bought some 5w30. Is that gonna be ok? how many quarts do i need to fill it with?
ok i went back and got the 5w 20.
OMG i am assuming u can't take the oil filter off by hand? guess i need to go get an oil filter wrench to take it off.
Do i need to put it on hand tight or tighten it with the oil filter wrench?
Tightening it by hand should be fine. But make it tight. And don't forget to put some oil along the gasket of the new filter.
There was DIY here in SL somewhere. Oh well, here's from Popular Mechanics' http://www.popularmechanics.com/how_...46.html?page=1
when taking it off use a leather belt to help you.
When tightening the new one back on you SHOULD HAND TIGHTEN it. 3/4 to 1.25 of a turn to the right after the threads begin to max out. Make sure the new one is snug and lubed up.
LOL its just an oil change. Get Mobil 1 or Royal Purple 5w-20. Use 4 quarts exactly, it actually calls for a little less then that but 4 is fine. You should be able to put on and take off an oil filter by hand. Dont be afraid of using a little muscle to take it off. I usually buy 4 quarts of Royal Purple 5w-20 or Mobil 1 Synthetic 5w-20 and I get a Mobil 1 M-103 Oil Filter or Fram PH4967. Good Luck
Originally Posted by 2_much_tc
i think the 05-06's were 5w-30... then the 07-on were 5w-20...
FRAM? I'd rather duct tape a pop can filled with toilet tissue and used tampons than use a FRAM piece of crap.
For an average priced filter, go with a Toyota, Wix or Purolator. If you want a premium filter, get the Mobil, K&N or Amsoil.
This engine came from the Camry line. The new corolla does use this engine now.
The manual says it's 4.0 quarts but I've seen different tC's take 3.7, 3.6 and 3.8quarts. And yes the oil was drained out completely and new filter installed.
Best thing to do is to fill it with 3.5quarts, then add until you can get it up to max without overfilling.
In 02-2006, Toyota release a service bulletin updating that all 06's should be using 5w-20 oil. The 05's have remained 5w-30.
In 2007 the engine was redesigned (think tweaked) and they changed the oil to 5w-20, with an option to run 0w-20. This same engine is used today.
Originally Posted by beastC
i run mobil 1 synthetic low friction 0w-30 and i'm boosted and my car runs alot beter this way than it did on 5w-30
lol i was thinking of going 0w-20 but that stuff is water thin...
http://www.knizefamily.net/minimopar...reference.html
Very Interesting...Mobil 1 oil filter for me from now on....
Music City Scions
