oil filter
Old May 15, 2006 | 08:03 PM
btodailly's Avatar
Default oil filter
same as corolla correct? fram 4697a i believe?
im having the worst trouble getting the origional off. tried with the filter wrench and its foinf nothing but denting the filter... and my man power just isnt working without grip .... help! what did you guys use to get this off with?
Old May 15, 2006 | 10:22 PM
nytlemgr's Avatar
ph4967, i used a filter wrench & did indeed dent the filter but it came loose. I have been told a heat gun will help a great deal if you can not remove the old one. When you do get it off ensure you put fresh oil around the gasket to ensure this doesn't happen again.
Old May 16, 2006 | 12:55 AM
Max's Avatar
Max
Please, for the love of your engine life, do NOT use a FRAM filter.
And a wrench will help you out. You can get one for <$10 at your local auto store.
Old May 16, 2006 | 03:00 AM
cadaver's Avatar
just get a set of large channel lock plier sand have at it!
Old May 17, 2006 | 01:27 AM
SciontCya's Avatar
Big Sky Scion
In a pinch, a piece of sandpaper wrapped around the filter often works.
If you're really screwed and dumped your oil before you found this out, you can drive a screwdriver into the filter to get it turning.
Don't ask how I know that...
Scott
Old May 17, 2006 | 01:36 AM
jct's Avatar
jct
Scott
you most likely heard that from around here like i have
i've dented mine before and kept twisting it off untill i got it off
brett561tc
Sep 15, 2015 06:33 AM
dgm458
Scion xD Drivetrain & Power
Aug 24, 2015 04:44 AM
boxcar87
Jul 12, 2015 12:16 AM
c_dog
40
Feb 2, 2005 12:08 PM
NemoBronsky
Mar 3, 2004 04:47 AM
