...Oil Plug Size Question....
What size socket will I need to remove the oil plug? Is it 14MM?
And does anyone know if the replacement magnetic oil plug can be removed with the same socket? Is it the same size?
I see them on E-BAY and I may put one in for kicks.
Thanks for the info......
The drail plug is 14 MM, as I just learned. The threads will fit, the thread size is avalible in several oil plug threads, I forget the size, but it will fit.
I have a long breaker bar with a 14MM socket on it that is dedicated to oil changes.
So when I start doing oil changes I can use my 14MM and not have to look for another socket.
The threads are a standard size. It will fit in your TC, unsungfate!
rain7905643
Mar 14, 2015 12:48 AM
