rattle from rear
Old May 6, 2004 | 06:09 PM
xb's Avatar
xb
Default rattle from rear
when i drive / turn my xb hard, i hear the rattle from the rear passenger side, around the rear seat, sometime it come up when i park the car. is ther anyone can tell me where it come from? my car's everything is stock, and no cargo net or cover behide.. thanks
Old May 6, 2004 | 06:16 PM
dinkjs's Avatar
take advantage of your warranty and take it to the dealership
Old May 6, 2004 | 06:19 PM
XBman's Avatar
Old May 6, 2004 | 06:24 PM
dinkjs's Avatar
Good advice man....I say take it too the dealer too! :D
Old May 6, 2004 | 07:44 PM
xbchance's Avatar
Is yours a high pitched squeal of a rattle? I have the same thing, and i took it to the dealer and they couldn't "replicate the problem at this time." Problem is it doesn't always happen.
Mine is usually only at freeway speeds when I'm turning to the left [curving to the left].
Elsewhere in this forum there's a TCB about rattle on the backside of the rear seats, but it seems to involve bolts that are loose. I tried this but these bolts were on so tight, i couldn't even loosen them (i know, I'm a wuss)!
So, I'm going to mention the rattle to them every time I come in; hopefully i't'll magically re-appear one of those times. :twisted:
Old May 7, 2004 | 02:26 PM
xb's Avatar
xb
yes, that's what i get from the rear.. the dealer is my friend, i talked to him yesterday, he told me he had the same thing happen in his one also, so i think they couldn't fix it at all, now.
i'm thinking to wrap the bolt with somthing to stop it. :?
Old May 7, 2004 | 09:24 PM
Yoshi's Avatar
I highly recommend you take it in and bring the TSB found here:
http://home.earthlink.net/~frazsj/SQ...ERVICETIPS.pdf
Took mine in and it solved nearly all of my rattles. On the back seat I also recommend putting some tape around the bracket the seat lock catches on.. Sorry I don't know the right name. Basicaly this is what you do:
Flip down the back seat; take a long, thin piece of electrical tape; wrap it around the upper arm of the bracket (I wrapped it about five times around).
That's it. The catch of the seat lock will sit more firmly and will no longer rattle. But the seat fix in the TSB helps as well.
I also had some big issues in the cargo area, specifically with the spare's rim getting clobbered by the tools and a screw from a sub bracket. Used some auto weather stripping, 3/4" thick, and fixed that.
Old May 8, 2004 | 12:46 PM
xb's Avatar
xb
thanks for your advise, i will do it the same way, :D
Old May 9, 2004 | 01:24 AM
Yoshi's Avatar
Just realized I phrased it wrong, there is no "upper arm," but once you flip the seat forward you'll see what I mean. There'll be ware on one arm and not on the other, the one with ware is the one to wrap.
Good luck!
Old May 9, 2004 | 07:07 PM
Guest
Guest
Posts: n/a
Default Re: rattle from rear
Do you have a trd exhaust? Just checking to see if it might be the axle back.
RY_TC07
Jul 18, 2017 05:18 PM
njb411
May 18, 2015 02:28 AM
alexxfender
Apr 1, 2015 03:06 PM
brownSys
Feb 27, 2015 04:20 PM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
