Rear wheels rub on stock Scion XB
Three of my co-workers and I went out in the Xb and, when I would turn, the rear wheels would rub. This is the first time I had 3 passengers in the car (2 in the back). They are full grown adults, but not obese or anything extraordinary.
Has anybody else experienced this? This is unacceptable for a car that's supposed to be able to carry 3 full sized adults in the back seat.
Originally Posted by Munch
Wow that sucks. How much was the total weight in the car :?:
It rubbed on both sides, if I remember correctly. I guess I'll have to wait and see the next time I have people back there.
I have had close too 1200lbs of people in my box, our golf 4 some. the smallest is 250, and it never rubbed, the wieght was more because we had our clubs also. Mycar was under powered then. Adam and James has seen some of my friends were not light wieghts. Bill
Originally Posted by bBted
what kind of springs u have??
it shouldnt rub...
theres a little plastic piece u can cut it off, someone did that already, but he has 225/40/18 tires in the back
it shouldnt rub...
Originally Posted by ChickenAdobo
Originally Posted by ikonXone
stock wheels?
oops...i didnt see that sorry...
it shouldnt rub, i have loaded 5 adults in there without rubbing :?:
surprised no one has mentioned this yet... but could it be the added weight of your sunroof?
they usually add a couple hundred lbs. depending on the type and size. anyways, i'd add up the weights of occupants and the sunroof and see if your exceeding the limit.
I was gonna say take it to your dealer, and have a couple of them sit in the back while you drive around, but....... if you have an aftermarket sunroof, and the added wieght is causing the rub, then your screwed. Something like a sunroof would probably void any warrenty, the dealer will just look for a way out of it. JMO
Guest
Posts: n/a
ChickenAdobo , where have you been man. we have been waiting for you to stop by the shop! :D It sounds like maybe you have something else rubbing or maybe your shocks are defective. It can happen, let me know if you want me to throw the car on the car on the rack to inspect it for any scratches.
I haven't had any rubbing, and I had two Drill SGTs in the back seat that totalled at least 450 lbs between them. Not too mention the 250 lbs'er aand my fat 210 lbs in front. Oh, I forgot to add that I have the 2 inch Spy drop, Hotchkis bars, and 17x7-42 offset w/ 205/40 tires.
DelMarVa
Scion Tuners
DelMarVa
Scion Tuners
Originally Posted by TheRedBox
when i lowered my car and had passengers in the back it rubbed for 2-3 days but seems to go away..
yea i would check weight of sun roof and pass but it still should not rub, i have 19"s
and had a guy that gose an easy 350 buy him self and his boy in back no plus my system and my box is welded in under car so i would hit up stylis and get it checked out
