Scion xB Lower Control Arm Caution
hello everyone... i was doing a oil change today at my shop and i took a look under mah car and checkd everything out to see if everythings in good condition and i noticed mah left front lower control arm is pushd out a lil bit and my right side is okay...
so just be aware and keep an eye out for ur lower control arms. ill post some pictures up tomorrow.. cant seem to find my digi cam =(...
-mark
-mark
Guest
Posts: n/a
Chrno you freak!!! The reason your arms are like that is because you drive your scion like its a drifter from japan!!! Your always trying to taunt me to take you on a hill that makes your car bend in ways that only a heavy car can take. Thats why you blew out your rear tire and had to run on your spare for two weeks!! Dam it chrno!;you need to slow down and bring me breakfast at shop monday! :D oh yeah SLOW DOWN!!!
You haven't been towed recently, have you? I've seen it twice now in SF - towing away a car that was parked close to a curb in front or near another car... The tow truck driver just hooks under the front driver's wheel and drags the car out sideways until he can get to the front. First one I saw was a Jag, the second, an Exploder. The wheel is left sticking out at a weird angle and the owners probably never know why their alignment is suddenly off - or worse...
man... dont be snapp'n on me... if u knew about lowering your car, the center weight of gravity puts even more weight and stress on the lower control arms and in some case's they do come loose, they are machine pressed. get some of ur knowlege straigth before you come snapping at me homeboi
and hell yeh i'll carry a warning sign on me once u see me ryden ur a$$ off the road
Originally Posted by Chrno
no no toes no nothing, and dealers probably wont fix it cause after market springs and yeh i hit a kurb a while back at 2mph other then that everything else is perfectly fine
Been there, done that with my last 2 civic's. Feels nice having a 100% stock car because I've been through $hit like this in the past......
