ShowOff Shine - Detailing results
Old May 7, 2005 | 12:42 AM
xBino's Avatar
Old May 7, 2005 | 12:55 AM
M-Flo's Avatar
Originally Posted by pkg
How often should we wax? do it every wash?
There is no set schedule on when to wax since there are many variables like weather, type of driving, etc. The way to test if you car needs a new coat of wax is while you wash your car, pay attention to how the water beads. If it beads on the car, then you'll need a fresh coat. If it slides right off, then you good till your next wash.
I normally wax my car every other wash (I wash my car every Saturday). I drive my xA daily, 30 miles a day. It's also parked outside in the sun for the greater day and garaged at night. With this schedule, I can keep a fresh shine everyday plus the paint is still as smooth as a baby's butt the day it left the dealership
I was thinking of doing the cleaning wax on first, followed with the caruba?
Imo, I would stay away from cleaner waxes. Why? Well, your car should be squeaky clean by the time you start waxing! Either with a good wash or with claying, not with your wax since it's your final step.
The only prep work for wax needed is some detailer's spray to enhance the gloss of the paint and prep it for wax adhesion.
What about mixing waxs?
From experience, I would not mix carnauba with synthetic waxes. Zaino is the only exception I've found since once it is cured, you can apply on top of it without affecting it. It even enhances the gloss to a whole new level :D
So which type of wax to choose? It depends. If you're looking for a long lasting, better protecting finish, synthetics are the way to go. If you're looking for the best glossy show car shine and not worried about longevity, stick with carnauba.
Old May 7, 2005 | 05:08 AM
Big_Bird's Avatar
Originally Posted by TeamMightyMiniz
a clay bar removes the grit and grime that contaminates leave on your paint's finish. If these contaminates are not removed regularly, they will damage the paint surface.
Contaminates also cause oxidation, which can be remoived with a clay bar.
When using the clay bar, follow the directions as printed on the product packaging.
You will FEEL the contaminates being removed by the clay bar. It's a satisfying feeling, knowing you are removing all that grime.
The results = glass smooth finish which is now ready for polish..
Originally Posted by Satmax
After reading MOTHERS detail guide, I learned the clay bar is the best damn thing to clean contaminants off your car's finish. You spray car detailer to "lube" the surface you're going to drag the clay bar across and you'll remove embedded particles in the paint that aren't removed by regular washing. Since the clay bar effectively removes contaminants, it also removes your car's wax. So plan on re-polishing/waxing after using a clay bar.
This is a good read at MOTHERS website:
MOTHERS Detailer's Guide
I'm going downtown to search for this clay bar, it sounds like it works pretty damn good.
ok cool, thanks guys, i gotta run out and pick one up tomorrow
Old May 7, 2005 | 05:58 PM
Satmax's Avatar
Sun is out and the weather is great! I'll post pics when I'm done.
Old May 7, 2005 | 06:10 PM
rynobox's Avatar
Looks like I need to take a trip out to R&S Strauss...
RA31925's Avatar
Well I picked up MOTHERS clay bar. It has been cold and raining today so I haven't
been able to start cleaning the car yet.
Instead of sulking inside the house waiting for the rain to stop, I had a little craft time.
Enjoy.
MOTHERS Clay Bar Release Series 2.0
nice bar. i need to go buy a new one. my dog ate it
Old May 7, 2005 | 06:11 PM
2tone_xB's Avatar
Great pics everyone.
Old May 7, 2005 | 10:30 PM
Satmax's Avatar
Damn! This clay bar is amazing! I started on a side mirror just to see how well it works. Using the detailer spray and very light rubbing, I could FEEL the bar pull in some spots. After a few strokes, the pulling subsided. I went back over the piece with a microfiber towel and detailer spray to clean it up. Used Mothers polish then 2 coats of sealant followed by Meguir's Gold Class wax. O-M-F-G. The side mirror looks like it's always wet!
Now starting on the rest of the car.... gonna be a long night.
Old May 7, 2005 | 10:35 PM
M-Flo's Avatar
^^^ Another enthusiast converted!
Some side tips~ use plenty of detailer spray and don't clay dry areas! Apply only light pressure (one or two fingers) and knead your clay often. Don't drop the bar! once it's down never use it again. Also, break the clay bar in half for easier use and save the other for next time.
Old May 7, 2005 | 10:48 PM
reagulator's Avatar
is there a special way to store clay? like in the fridge or freezer? I just keep it in a zip lock.
Old May 7, 2005 | 11:20 PM
bubblemyster's Avatar
I just ziplock it. Keep it in the garage with the rest of my stuff. Works great. Especially cause my garage is warm and keeps clay nice and sticky.
Old May 7, 2005 | 11:35 PM
M-Flo's Avatar
Zip lock or saran wrap will keep the clay soft and moist for a few months. Spray a bit of lubricant on it before you wrap it to keep it lasting long!
Old May 7, 2005 | 11:48 PM
YELOSUB's Avatar
Wagonistas
Here's our's. Use all Meguiar's cleaning material, the best IMO. I like this thread!
Whoever wins, congrats to them.........
Old May 7, 2005 | 11:50 PM
YELOSUB's Avatar
Wagonistas
^^^^The reflections you see are the houses on the other side of the street, just fyi...
Old May 8, 2005 | 12:22 AM
Satmax's Avatar
Yelosub, your xB looks like it's got wet paint all over it. LOVE IT!
I'm just finishing up the roof on my xA, I'm pretty pooped... I might wait till tomorrow morning to finish the rest. Sure wish I had a garage....
Old May 8, 2005 | 12:29 AM
YELOSUB's Avatar
Wagonistas
Thx Satmax, it's alot of work but well worth it at the end. Good luck on the Shine, and yes a garage helps tremendously...
Old May 8, 2005 | 12:47 AM
The_Instigator's Avatar
Just did mine. Clayed, used 3M 39009 Polish for Dark Cars with Porter Cable DA buffer. Followed up with Zaino Z2 and a wipedown with Z6
It looks glossier in person...the mica in the paint breaks up the reflections on camera
Old May 8, 2005 | 07:40 AM
Brad2005tC's Avatar
just waxed/detailed it a few days ago..tell me what u think!
Old May 8, 2005 | 07:47 AM
Satmax's Avatar
Hmmm Flint Mica sure doesn't seem to take very good pictures outside. The garage pics show the reflection pretty well. Nice!
I'm worn out... I have the lower part of my car left to do.... sleepy time.
Old May 8, 2005 | 10:49 AM
Imthekingman's Avatar
heres a few older pics of my tc
