Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Maintenance & Car Care (https://www.scionlife.com/forums/maintenance-car-care-1604/)
-   -   Squeaking noise in the back of XA driving me NUTS! (https://www.scionlife.com/forums/maintenance-car-care-1604/squeaking-noise-back-xa-driving-me-nuts-934/)
2002cbr600f4i Dec 12, 2003 03:00 PM
Hey gang,
Have had my xA for nearly 2 weeks now. LOVE it. BUT, one thing is driving me crazy. Every time I go over a large bump (like say a speed bump, or a change in road surface) I get this really annoying squeak/ (plastic/glass) cracking type noise in the back. I haven't been able to figure out what's causing it yet. It's driving me nuts though. It's almost like there's a piece of plastic rubbing or tight or something like that.
Any suggestions? I guess I could take it to a Toyota dealership and have them mess with it...
--Mike
magpie13 Dec 12, 2003 11:40 PM
I get that noise when I don't lock the backseat(s) in place.
Otherwise it's a quiet ride...
El Dingo
dickpeter Dec 13, 2003 12:59 PM
There is a TSB for rattles and sqeaking from toyota.
NV008-03
fortyninerhater Dec 13, 2003 03:32 PM
I get a noise coming from the back of my Xa also. I turns out that it's the tonneau cover. Pull it out ans squirt a little oil on the end that pushes in. It worked for me. Good luck.
-E
DoNuT Dec 13, 2003 04:12 PM
-E
It rattles for me, because when I go over a bump, the little flap bounces up and down. If you extended the cover out and locked it in place, I believe this could be fixed, although I haven't tried it myself yet =P
fortyninerhater Dec 14, 2003 05:01 AM
I see. I had that problem in my Rav4. What I did to resolve that was tape on some velcro (the loop side) so that the tonneau rests on the fabric. It also tightens the fit. Give that a try. It may work in the Xa too.
-E
Dylan Oct 4, 2004 01:35 PM
-E
What is the tonneau cover? I get a similar noise from the back area of my xB and I'm not sure what it is. I've checked out nearly everything that people have suggested on the forum but haven't come across this "tonneau" cover issue. Please advise.
Thanks,
Xcalibur1986 Oct 5, 2004 12:00 PM
I had this really bad, too. It turned out to be the spoiler. If you have one, go and see if it moves when you try to move it. If it does, and makes that noise you've been hearing, get the dealer to fix it. This really annoyed me, but it's only if you have a spoiler.
Dylan Oct 5, 2004 01:10 PM
No spoiler here. I've checked out other things like taping down the metal wires under the back seat's fabric. Also, I've taken off and put back the cargo cover and the noise still seams to be there. It's a slight squeaking/tapping/clicking noise. Really odd but also really annoying (when music isn't blarring of course).
Dewmerz Oct 5, 2004 03:14 PM
As crazy as it sounds look at the 3rd brakelight cover. On my xB I have had it break twice and am having the dealer put on the 3rd one today. The tab inside cracks allowing it to touch the glass lightly making noise. Mine even vibrates between 2800-3000 rpms.
Not sure how the brakelight cover looks on the xA...
Dylan Oct 5, 2004 04:09 PM
Thanks for the idea. I'll check it out.
I've noticed water condensation inside the brakelight covers. Since I never use a high-powered spray to wash my car, it's odd that water would get in there so easily just from daily use.
Dylan
bB2NER Oct 11, 2004 11:21 PM
Have someone ride in back then drive the car over the same spot. they should be able to pinpoint the area of the noise then start pulling stuff off til it is found.
TheScionicMan Oct 11, 2004 11:38 PM
What about the license plate? Is it mounted nice and tight? Maybe dynamat it...
© 2026 MH Sub I, LLC dba Internet Brands
