windshield wiper specs.
(I did a search first...no hazing.....
Windshield wiper specs and could not find anything. All it told me was how to operate and use the washer fluid......... am I missing something?
Anyway, Time to replace the wiper blades, anyone have the size???
How do you replace the rear wiper?
Thanks,
Matt
Thanks,
Matt
I just asked the attendant at the store for wipers. He should be able to tell you what size. I happen to forget the size, but I'll go look for the blister package when I get home (if it's still around). It should be written on there...
Originally Posted by shangtsung
It might be more helpful to call the subject of your post "Windshield wiper specs" instead of "I looked in the manual for......"
Matt,
I believe the driver side is 24 inches and the passenger side is 15.5 inches, the rear is like 11.75 inches. I know what ur thinking, "Where am I gonna get 15.5" wipers?" I ordered mine from brandsport.com. They have all the right stock size. I went into Pep Boys and their recommended replacements were Bosch's Microexcel: 24" for driver and 16" for passenger (which DOES NOT FIT properly). I promptly returned them and placed an order online.
You dont replace the whole whiper ( I believe) You could just replace the wiper blade...
or you can always go into the dealer and pray that the service department has some clue...haha
Matt, LOL. You really should try www.brandsport.com if you can wait a couple of days. They have real toyota replacement blades. I'm not sure how their prices compare with the dealerships though.
The box is listed as a 20" ( 20-1 ) in PepBoys. The doorstop is listed as 2 different sizes. I had a Neon that was the same way. You have to purchase 2 sets to get the job done.
BTW ... youll be hard pressed to find re-fills. Most parts stores have the replacement. Actually, its not a bad idea, cause the new metal has more spring in it. To keep the wiper snug against the windshield.
Originally Posted by mattxb
... How do you replace the rear wiper? ...
I have not tried removing the rear wiper yet. Please let me know if it comes off easy... or if you break the plastic stuff and wish you never tried.
Thanks. RPM
Thanks. RPM
Thanks. RPM
and the whole process took about 10 minutes well 20 for me cause i was watching tv while i was doing it too very easy to do!!!
Finally I went to the dealer, and after waiting in line for 20 minutes (and I was the second person in line) the conservation went something like this:
"I need two sets of wiper blades, one for an '05 Scion tC and one for an '05 Scion xB."
"We don't have those in stock."
"How does your oil change place replace them when people ask?"
"We cut it to fit."
"Can't you just look at a tC and and xB that you have for sale and cut to fit?"
"Ummm."
So then he gets out five blades, none of which are clearly long enough to work on the driver's side on the tC. I say, ok, I brought my tC, I'll go bring in the blade I need replaced. I go out to my car, take it apart, and bring in the blade. By the time I'm back in he's gotten another blade that is much longer and it will work. So then they send me on my way, wallet 20 bucks lighter for the 5 blades.
I get home, and start cutting them to fit and putting them together. Get both done for the tC no problem, do both fronts on the xB no problem, get to the rear window on the xB, and the new blade won't fit into the blade holder. Turns out the xB rear window uses a narrower guage of rubber.
Drive back to the dealer, this time in the xB, take it back into the dealer along with the original stock wiper blade. Different guy at the parts counter, takes the stock blade from me and disappears for a few minutes. Brings it back, "you sure this was the original blade?" "Yes, its the original". He pokes around in his computer for a while, says they don't have it in stock and will need to order it for me.
What kind of a mickey mouse operation doesn't keep consumable items in inventory? I swear, I should start a blog - something ending in "sucks.com" comes to mind.
when i got my blades they didn't have the rear one in stock they ordered it and next day or two i got my rear blade and installed it
when i got my rear blade they gave me two extra front blades when i ordered 'em
Xaphoon
Sep 21, 2015 02:18 PM
