wipe off clay when done?
All you have to do is to kneed the clay until its white again. Unless you have hard chunks in your clay ie:dropping it on the ground, you should thrpw the whole piece away. its better to be safe then sorry. I usually do the soapy water method when i clay. I have the hose in hand to wash off the dirty water and to keep things moist.
Originally Posted by Max
I keep the surface wet by using detail spray.
You don't need to keep the car wet after claying. Clean it right after claying.
im also wondering, how long are u supposed to keep the clay on your car before removing it (cleaning, wiping off?)
Here's one web site that explains how to use a clay bar.
http://www.autopia-carcare.com/inf-clay.html
When I was using the claybar to remove the bugs earlier this week, what I did was spray detail spray, then rub the clay bar until it felt like it was gliding over the area, then wipe off the spray with a microfiber towel, look at the bug spots and repeat until they were gone.
I managed to get almost all the bug stuff off my car, not sure what to do about the remaining, as the bug off stuff I bought didn't work nearly as well as the clay bar.
I clayed my hood and roof tonight, then a coat of Meguiars NXT wax. This was the first claying in several months for the hood, and the first ever for the roof. The difference is pretty amazing.
Smooth as glass.
Dumb question: Does clay take off wax?
Smooth as glass.
Smooth as glass.
Smooth as glass.
Originally Posted by xnevergiveinx
clay does not take off wax. alcohol mixed with water or dawn dish soap will take off wax. clay sorta acts like a pencil eraser, it picks up all the gunk on the surface of your clearcoat
I was curious for future use, I didn't want to take off any wax, but it's good to know. Once I get my garage, I'll strip everything and get a fresh start. For now, I'm loving my finish. Over a year outside, and no swirls, just the rock chips on the lower bumper.
Originally Posted by Lonely_Raven
If you are using clay to get a rally smooth finish and prep for a good waxing, do the following.
First, wash your car thoroughly with DAWN dishwashing soap. This takes wax off, the clay will also remove wax.
Then, follow the instructions we've provided you here, watch the step-by-step, with the clay.
Then, wash your car again to remove all residual clay.
Then you are ready to lay down your wax.
Dude, if you still don't understand how to use clay after reading the advice here, after reading the step by step, after watching the video, don't use it.
is it necessary to wash again after claying? cause i was thinking of wiping it off with detail spray if some clay residu are left behind.
anyone clay their car using these steps? (the part where you wash again after claying)
Originally Posted by B1uEsC1uEs
oh ok thanks.
I've never seen any clay residue, perhaps you're not keeping it wet enough. My Mother's kit said not to use water, but to use detail spray. I wipe the area with a microfiber towel after claying so the detail spray doesn't dry on it, then wax afterwards. Claying DOES remove wax, it basically removes all the stuff built up on the surface of the paint. But better to strip the wax with the wash.
DON'T wash with dawn or any other DISH liquid!!!! any good car wash will remove wax......dawn and whatnot will promote fading of the paint over time....also, good quality car soaps contain lubricants to cut down on swirl marks....
