96 Maxima Turn Signals Problem
ok my turn signals dont work they will come on for 2 secs when i first start the car they will blink 2 times then shut off and the same with the hazards and i checked all the fuses.
if anyone can help id love it |
HELP PLEASE
have you replaced the flasher relays they are normaly like in a small round tin can like relay
were in the car
under the dash maybe near the fuse block, does your brake lights work too? might want to check that also
yea everything works fine the switch works for the lights and highbeams just the turn light comes on and blinks 2 time then stop and if i shut the car off and wait like 5 mins and restart it does it all over again
it might be the turn signal switch behind the steering wheel its easy to do just a slight p.i.t.a to replace
when ever you have to turn just shut the car off and wait :P
you can always do hand signals :-/
Replace the hazard switch... :lalala:
lol hand signals work lol
i'm betting its a switch of some sort under the dash/in the steering colum or where ever its located at
i was thinking the same but it works for a bit then the hazard the button works the same
were is the switch
its the switch that you turn it off and on at :wink:
i know lol but how would that afect the turn singals when they both have the problem
ok is thier anyway to bypass
or anything else i can to check to see
