FS: Ceramic Centric Front Brake Pads
For sale front brake pads, never used and still sealed. $35 Shipped. Shipping is going to cost me 15 dollars because they have some weight to them! Please message me. Thanks
Centric Posi Quiet Ceramic Front Brake Pads-tC 05+
Name: Centric Posi Quiet Ceramic Front Brake Pads-tC 05+
Serial Number: 105.08170
Posi Quiet brake pads are manufactured using the same positive molding process utilized by Original Equipment suppliers. Positive molding uses extreme pressure to compress the friction material and bond it to the backing plate. This process assures consistent friction material density throughout the pad, resulting in even wear and performance characteristics throughout the life of the brake pad.
The number one cause for customer returns are noise and vibration. Centric Parts has recognized these issues and is constantly improving its products to eliminate these issues. Posi Quiet brake friction features either precision cut or shaved backing plates and mechanically attached shims; these small details ensure proper fitment in the caliper and virtually eliminate noise associated with pad vibration. In addition to these features Centric Parts has added a scorching process to all of its Posi Quiet brake pads. This additional process forces any impurities out of the friction material and pre-burnishes the pads to greatly accelerate the break-in process.
Posi Quiet brake pads are available in three application specific compounds, each formulated to match O.E.
• Longest wearing most advanced material available
• Lowest dust
• Stable friction performance across wide temperature range
Extreme pressure compresses the friction material creating a more consistent material density throughout the pad This process utilized by O.E. suppliers is the most advanced available today.
Precision cut or shaved backing plates reduce vibration and noise by ensuring proper fit in the caliper. Correct fitment results in even pad wear and consistent braking power throughout the lifetime of the brake pad.
All Posi Quiet brake pads feature mechanically attached, application specific shims. These shims provide superior noise abatement compared to lesser adhesive or drift-lock style shims utilized by other manufacturers.
Scorching
Posi Quiet pads are the only full-line of aftermarket pads that are scorched. This OEM process enhances key friction performance levels. Scorching raises initial cold effectiveness, stabilizes friction levels right out of the box, provides consistent performance across the entire operating range.
During the scorching phase; each brake pad surface is super-heated to simulate the initial break-in process performed by installation technicians. This additional step removes any uncured bonding agents eliminating the need for initial break-in and reducing noise caused by pad glazing. Scorching thermally conditions the pad material which yields a more consistent and higher friction level right out of the box.
Scorching benefits the vehicle owner by promoting a more complete bed-in of new pads, increasing the
effective stopping power from the first stop.
• Lowest dust
Scorching
TotalChaos
Apr 7, 2015 09:02 PM
TheTripleC
Jan 4, 2015 06:46 PM
