FS/FT: ichiba v2 15mm spacers
I have 3 month old spacer that I no longer need im looking to get 120 shipped or 100 local pick up will also take trades just offer up will post up pics when I get off work
Sushi Free bump for a great seller!
? - did you have any issues with the spacers? abnormal vibrations? added stress to the hub? abnormal wear around the hub? are these hubcentric?
Thanks!
Thanks!
I've had no problem with these spacer and no vibrations what so ever there hubcentric so it's just like stock
did you need to run shorter studs to clear your stock studs, very interested but i have 15mm and 20mm they were v1 and did not clear but if you had no problems i will jump on these...
With these also the studs needed to be shortened a bit. even with the 20mm they had to be shortened a bit
CSOCSO
May 15, 2012 10:32 PM
thekevin
Sep 17, 2010 06:31 AM
