optionJDM: Hotchkis Springs/Sway Bar For 08-09 Scion XB [Canada Only!!]
Hotchkis Springs: 2008 -2009 Scion XB
Description:
Lower the ride height, reduce body roll and increase chassis response of your 2008 Scion xB with Hotchkis Sport Coil Springs. These springs lower your car 1 3/8" (35mm) front and 2 ¼" (57mm) rear to give it just the right look with an aggressive stance and a lower center of gravity. Hotchkis Performance Springs were developed as a complete front and rear, balanced system, providing the ultimate in coil spring improvement. They work well driving your favorite twisty road or just cruising around town. Precision wound in the USA from the highest quality high tensile steel and finished in our durable gloss gray powdercoat.
Features:
-Provides sport lowering of front 1 3/8" (35mm) and rear 2 1/4" (57mm) -Precision CNC wound from high tensile steel for increased spring travel without coil bind and related noise
-Engineered with proper pre-load to maintain positive spring location throughout complete suspension travel
-Shot peened and pre-set for increased performance and long term durability
-Finished in durable gloss gray powdercoat
-Benefits: Precision CNC wound in the USA from high tensile steel for extremely durable and efficient operation Lowered stance removes much of the fender/ tire gap- xB looks much better
-Balanced spring rates for great driving performance and a comfortable sport street ride Lowers center of gravity for improved handling and high speed stability
-Engineered to work well with OEM or aftermarket shocks
Hotchkis Font & Rear Sway Bar: 2008 - 2009 Scion XB
Description:
Designed and manufactured by Hotchkis Sport Suspension specifically for the new 2008 redesigned Scion xB. Our street Sway Bar package features massive 32mm tubular front and 25mm rear sway bars for enthusiasts looking for a distinct, balanced handling advantage. Unique Hotchkis polyurethane bushings and heavy duty bushing brackets are also included along with zerk fittings for easy lubrication. The new Scion xb; while tremendous fun in stock form, just got even more exciting with the addition of Hotchkis Sport Sway Bars.
Features:
- Lightweight, durable 32 MM (1 1/4") tubular steel front sway bar. 50% stiffer than the stock xB front sway bar.
- Lightweight and durable 25MM (1") tubular steel rear sway bar.
- Includes unique Hotchkis polyurethane bushings, heavy duty triangle brackets and special hardware.
- Welded on centering rings
- Gloss anthracite powder coat finish.
Benefits:
- Dramatically improves cornering potential due to increased front/rear roll stiffness
- Offers distinct handling advantage over just stock front sway bar set up
- Balanced front and rear sway bars allow xB to handle exceptionally well. Our unique front sway bar offers excellent chassis repose and quicker directional changes
- Comfortable sport ride quality
- Easy to install and thoroughly tested for the utmost in durability and performance.
PM For Special Pricing [Canada Only]!!
TheTripleC
Jan 4, 2015 06:46 PM
hampton1100
Jan 2, 2015 08:13 PM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
