Help with installing an amplifier for my TC
I'm trying to install an amplifier into my TC but I don't know where to run the power cable from the battery to the amp. Is there a place I can sneak the cable through from the engine, hood area, or would it be better to drill a hole? If I can get the cable inside where the passengers sit, I should be ok. I'm a total noob to this but I think it shouldn't be too difficult to do on my own.
Any help would be greatly appreciated. Thank you
Scion100, last week I installed a 2 & 4 channel amp. I have a hole drilled in my firewall on the driver's side. I gutted the entire car to run the power wire on the driver side to the trunk. I ran the speaker wires and RCA cables on the passanger side for the interior speakers.
Good luck
Good luck
On a tC that i did recently, i ran the power wire down the firwall and under the driverside footwell, pokerd a hole in the boot for the steering clooum and ran it through there, under the drivers seat and back seat to the trunk
TheRedBox
31
Dec 2, 2003 04:53 PM
